72 Cutlass heater core (w/AC) replacement
Old Sep 29, 2011 | 07:10 AM
Lady72nRob71's Avatar
Here is the start of the actual job, step by step:
https://classicoldsmobile.com/forums...tml#post362172
Got some questions along the way though...
<Original post>
Anyone have a detailed "how-to" thread or writeup on how to change this? This is for with A/C.
The CSM simply says "heater core core can be replaced after removing heater case and shown in figure x.x." Figure x.x just shows the heater case. In otherwords, USELESS!
I do know you remove the 4 nuts from the evap case under the hood and remove two screws inside to unsecure the case.
You also remove the slide cable and vac hoses, main plenum, and defrost ducts.
WHAT ELSE HAS to be removed to pull the case out? Radio? Glove box? Dash? Seats? Roof?
I hoped to not have had to replace this, but one of the nipples were crushed by a clamp long ago and new hoses will not reseal on it.
Old Sep 29, 2011 | 09:40 AM
ROCKET VAPOR's Avatar
Lance
Rob, I am also getting ready to replace mine. I have been reading thru an old post by "Grumpy" on Team Chevelle. Very detailed information almost like you wrote it!!!
I do know you need to look for all brass construction with curved tank, because the flat bottomed tank won't accept the retaining clip.
http://www.chevelles.com/forums/show...re+71+chevelle
Old Sep 29, 2011 | 10:11 AM
Thanks for the link...
The box itself looks not too bad. I am just wondering how much of the Olds dash needs to be dismantled for clearance. In the Chev, the dash pad had to come off, along with the vents. Perhaps this fall I shall find out!
I did get a Vista Pro 398226 unit from Oreillys that is copper and brass. Not sure what is meant by a "curved" tank though.
Old Sep 29, 2011 | 10:27 AM
oldsguybry's Avatar
NOVICE car nut
mannn , that sucks Rob .... you just got all that stuff put back together... wish I could help , but never had to deal with heater core before.... just remove it
Old Sep 29, 2011 | 07:24 PM
brown7373's Avatar
I replaced mine on my 72 a few years back. Mine is also factory air if that matters, but I did not have to remove the dash pad. Definitely remove the seat because you can lay down and get at everytrhing without being a contortionist. I'm 6 4, and even doing things like changing a blown fuse is really hard to reach with the (driver) seat in. I guess you could lay across a bench seat, but buckets and a console...forget it! I think I just followed the steps in the service manual, which I don't believe says to remove the seat, but trust me on that one.
Old Sep 30, 2011 | 04:39 AM
69442C's Avatar
Rob, I don't have experience with a 72 so I can't comment on what else, if anything, outside of what you mentioned, would need to be removed. On a 69 A body, nothing else needs to be removed.
I will mention a few things. The factory heater core uses a brace between the two tubes on the core and all of the replacements I have seen do not. I remove the original brace and installed it to the new core. It solders in place. I know you don't weld so can you solder? It makes a big difference in the rigidity of the tubes. Harder to move two than just one.
Also, when you pull that interior heater box, you will see there is a vacuum line that runs to a vacuum servo located on the far left of the box. The servo is on the rear side. I would suggest you replace that vacuum line while you have the box removed as you cannot get to the nipple on that servo when the box is bolted in place. I think the factory even installed a small vacuum line section and then used a splice since they knew the line needed to go on first. Sort of a mightaswell thing and very simple and inexpensive.
Brian
Old Sep 30, 2011 | 05:23 AM
69442C's Avatar
Brian
Correction, the servo in question is in the middle of the box and on the rear. The servo on the far left side is easily reached.
Also, while you are at it..... mightaswell replace the seals in that heater core box. I forget if you bought a seal kit when you did the AC box and if so then you already have these parts. You'll need to drill out 2 or 3 rivets to get everything apart.
Old Oct 2, 2011 | 01:58 PM
O's_Car's Avatar
Hey Rob, I replaced my heater core not long ago. Mine is a 1970 but it should be equivalent. I'll share some pictures with you so you'll know what to expect.
I had already removed the interior of my Cutlass when I got to the heater case, so I can't definitively tell you what HAS to be removed to get it out. I don't think the radio would be a problem, but the glove box and dash vent ducts might. Once you remove the attaching hardware and disconnect the vacuum hoses & control cable, the heater case comes straight out. The first 2 pictures below show why the heater case has to come out straight back: those threaded studs and the heater core tubes have to clear the firewall. There might be enough room behind the glove box, and you might be able to work around the dash vent ducts, but I don't know.
The back of the heater case consists of 2 covers, the one with the heater core is held on by 4 screws: three along its inboard edge and one at the outboard edge (third picture below). Brian mentioned in his post about having to drill out some rivets - those rivets hold the other cover to the case; you won't have to remove them if all you're doing is replacing the heater core. But you will have to remove the 3 screws that hold the temperature door actuating mechanism as they thread into the top of the cover (last 2 pictures below).
I'll continue the story in my next post...
Old Oct 2, 2011 | 01:59 PM
O's_Car's Avatar
With the cover screws and door actuating mechanism removed, the cover will slide away from the heater case with the core attached (first picture below). The core is held in place by 2 brackets which attach to the cover (middle 3 pictures below). The screws for the inboard bracket are located behind the temperature door (last picture below). Note the orientation of the brackets relative to the heater core - they cradle it at the bottom. Remove the 4 screws to release the brackets and the heater core is free.
As Brian mentioned, I replaced the seals between the case and the covers when I reassembled. I got a kit from Supercars Unlimited that had the pieces for the heater and evaporator cases.
Hope this helps. Let me know if you need more info, I took LOTS of pictures!
Old Oct 6, 2011 | 01:58 PM
Redline442's Avatar
I too am getting ready to have to replace a bad heater core....again!!! The first one was done by a shop that told me the right front fender had to come off for access. Is this true? I hope not, as I want to try and do it myself. Thanks!
Old Oct 6, 2011 | 02:06 PM
Lance
No, but if you remove the passenger side inner wheel well (plastic liner) it will make it easier to gain access to the lower outboard Pal nut.
Old Oct 6, 2011 | 07:12 PM
Looks like I missed the continuation of this thread...
O - thanks for the pics... What has to be removed before the heater case can be removed?
After it is out, replaceing the actual core looks easy. If it involves removing as much as the radio, another big set of MIGHTASWELLS comeinto play...............
Old Jan 22, 2012 | 04:39 PM
Post Here I go...
On a warm (74*) winter afternoon, I donned a t-shirt and shorts and set out to begin Lady's heater core replacement.
She has a bench seat, which makes the job a little easier.
I pulled the valience with the crotch-cooler vents, the main dash vent plenum, and the heater deflector vent.
Right kick panel had to be pulled, so that involved pulling the sill plate as well. So far so good.
Radio is fine where it is and the glove box cannot be removed without pulling the heater box, so i assume it stays.
I removed the three sheetmetal nuts that thread on to the heater box studs. (The hard to get to one was never installed after the evap box was installed).
Defrost plenum was unscrewed. The air temp door cable was unbolted, but cannot be removed from the air door. I used the camera to take a blind photo and it looks like there is a one-way clip on it (black thing on the silver stud). I guess I wait until I bring the box down to disconnect it? Or should I disconnect at the control head instead??
I tried to remove the outside air door for cleaning but it will not come out. It looks like 2 pieces, but IS IT? I remember a screw on the firewall side, so if the thing is one piece, it stays put.
So now I have it pretty accessible....
I ran out of time and did not want to drop it yet. I KNOW it will not just drop and be done...
Old Jan 22, 2012 | 08:57 PM
oddball's Avatar
The outside air box is stapled to a rubber boot that goes up and around the blower fan. You have to remove the fan and then the three bolts holding a flange retaining the boot to get the assembly out.
Also unnecessary for this job.
It's easier to unhook the cable from the A/C control.
Are you sure it isn't 4 main nuts? If the box is moving, then I guess you have your answer.
I enjoyed the weather today, too. Did some more sand blasting and finally POR-15'd the windshield channels. Got to do something constructive instead of just taking stuff apart. That's a first in about 15 months on my project.....
Old Jan 23, 2012 | 05:23 AM
Stapled - okay, that explains it!
I know it is not needed for core replacement, but I thought I would clean it up. Okay, bolts go back in it - no might-as-well! My anti-MAW helmet is working!!
Okay, I will look into this. I thought there was a clip on that, too. How DOES it come off? I layed on my little mirror yesterday and busted it. Now i cannot see up there.
Only 3. When I put the evap box in last year I left that evil lower right one off cause it was a pain to get to later.
I have not removed the two bolts from inside yet - did not want to go that far yesterday. Maybe this week some time.
COOL - Keep it up! Any pics? Resto thread?
We are having a pretty mild winter, so take advantage of it. Our humid 110* summer is just around the corner...
Old Jan 23, 2012 | 06:26 AM
oddball's Avatar
I'll post some pics tonight. IIRC, there's just a small bolt then it slides right off. I think the last time I did this in the car I actually unbolted the A/C control and moved it with the box. That'll get everything into the footwell, and you can swap out the core there. If the vacuum lines are original, then they are color coded so it's "easy" to reconnect properly.
I'll start one. Been trying to get a website going to document everything - I'm forgetting as much as I learn! - and then will toss some links over here. The problem is I spend all my free time researching and shopping for new parts instead of documenting!
Old Jan 23, 2012 | 08:17 AM
frankr442's Avatar
[QUOTE=Lady72nRob71;362172]On a warm (74*) winter afternoon, I donned a t-shirt and shorts
Yesterday was 28* and I donned two layers of clothes,boots and gloves to shovel 12" of snow. I hate all you southern people and your rust free cars!!!
Old Jan 23, 2012 | 09:10 AM
Hey - at least you guys have summers that you can actually go outside and enjoy! Over here, it is another 3 months of hibernation from June - August.
Old Jan 23, 2012 | 09:26 AM
classicjoe's Avatar
Im just loving this thread . Thanks Rob. I can count on you to tackle the tough jobs and give us details and photos on all the challenges that we might face. This makes me want to tackle my core replacement.
Old Jan 23, 2012 | 09:48 AM
frankr442's Avatar
I guess cold or hot comes down to personal preference, but you can't argue with the rust!
Old Jan 23, 2012 | 12:54 PM
I will post the rest of the progress when you are done so I can grade your performance...
Very true... Rust can be an issue here to cars that sit around lakes and under trees. TX is very humid in the summer, tree droppings hold the humidity, too. A budy of mine is restoring a rusty Ford that was stored under trees at a lake house. At least the frame is solid...
Now Arizona is the best for rust free cars, but throughout the south, plastic and vinyl rot fast.
Old Jan 23, 2012 | 07:12 PM
oddball's Avatar
OK, there's just a bolt, then a loop that slides over an arm. Here's a picture with them assembled:
And separated:
The bolt is 1/4"
Old Jan 24, 2012 | 05:26 AM
Cool!! I will try releasing that when I get home. I thought the assy manual showed a clip on it, but maybe that was for heat-only cars. Hope there's no clip!
Old Jan 25, 2012 | 03:04 AM
Yellowstatue's Avatar
[QUOTE=frankr442;362375]
The really great thing about having to wear several layers of clothing is that it prevents rips, tears and scratches on your epidermis when you are working around sharp edged sheet metal... I am still awaiting my regular allotment of the fridgid white dots...broom in hand, shovel on standby, tractor w/blade in shed just in case the weather guy gets really stupid... or somebody from out West sends me an Alberta Clipper...
Old Feb 4, 2012 | 10:09 AM
Smile Out it came…
So on another 70* February day under recovery from a nasty sinus infection, I could not be confined inside any longer. I was feeling much better, so I decided to yank that elusive heater box out so I could actually accomplish something.
Keep in mind, when I disconnected the heater hoses long ago, I blew through the core, to remove most of the coolant. You do not want this to spill inside should be box tip over!
With the dash assembled, it was next to impossible to see the temperature cable connection at the controls. I felt around up there and I found it, and there was a retainer on it anyway, so I decided to remove it from the heater box instead. The right A/C duct was carefully pushed to the side, the defroster adapter pushed up, vacuum hoses disconnected, and plastic put down to cover the floor. I removed the two 3/8” screws securing the box from the firewall and it moved some.
I ran my fingers between the box and the firewall rubber pad, as it was stuck to it some. Doing so it came away more and more. Careful finagling got the box to come loose and on its downward travel. I had to coax it to the left to clear the recirculate air door actuator. It is plastic so you don’t want to bust it!
It came down slowly and easily until I could remove the temp cable.
The clip is a one-time use thing.
I tried my best to remove it intact. However, Murphy’s law states “If you fiddle with something long enough, it will break”. That is exactly what happened, so the cable came off and I carefully removed the box from the car.
Here is the simple cause of all this mess. Note the nipples are crushed out of shape slightly from clamp overtightening.
It was once “fixed” with globs of RTV, but it was evident that it seeped for years anyway. I wanted to fix it right instead.
The left plate’s screws and the top door actuating mechanism were removed. Before the latter, I marked where the screws were for easier adjustment later. Note the different screw types and lengths! With the help of a putty knife to cut through the sealer, the core and plate slides forward…
Old Feb 4, 2012 | 10:32 AM
The core of the issue…
As you can tell, the hose leaks had caused some water stains inside in the dust. Nothing major though.
No signs of leaking or corrosion anywhere else.
This proves it is the original Harrison brass and copper unit...
I am going to keep this core and hopefully find a bad core with good pipes and make one good unit!
The new heater core is a copper Vista-Pro unit bought from Rockauto. Perfect fit for a Vista Cruiser I guess…
The cores looked much alike.
However the new one is lighter and flimsier than the old one.
The original weighs 3.5lbs, the new one only 2.5lbs… Typical modern cheapness.
I had to carefully bend the new one’s pipes into position, as they were not assembled quite aligned.
Old Feb 4, 2012 | 10:57 AM
Disassembly and resto…
Think I could just pop the new core in and be done? Heck no – this thing is dirty!
Time for a quick resto!
The old heater core was removed and the straps (with surface rust) were tossed into some derust solution.
The temp door retainer clip was carefully pried off and the plastic bushing was removed from its shaft.
The door was extracted through the heater core side hole. It will not come out the front hole.
Here is the aluminum core frame – “Super Cast” it says on it… Note the sealer that was used around it that needs to be scraped off.
The hose and clip was removed as well as the screws on the right side plate. There are some rivets holding the lower right plate on, so I decided I will not drill them out since there is not need to disassemble it all. It can be cleaned up good enough as is.
So here is the pile o’ parts, ready for wash!
After an attack with Simple Green, brushes a scraper, and a water hose, these parts were done.
The rest of the box will get a more careful wash, since I am not tearing it down completely due to the rivets.
Note the green dime under the louvers…
Old Feb 4, 2012 | 12:25 PM
Final cleaning…
The next afternoon, though a bit cooler, I finished cleaning up the heater box inside while sitting in the sun by the window. I had carefully washed most of it outside yesterday.
Looking good so far, no drama (surprisingly)…
Only thing strange I noticed was on the defrost/heat selector door…
It appears there was a foam seal at the end of it, which was mostly rotten away. Some of it is still there on top but not much. This is in heat position.
A little of it can be seen on the bottom side, too. Note the three staples and the pattern in the metal. This is in defog position.
I may try to improvise something to make sure not too much air comes from the defog vents while in heat mode (to prevent dry eyes). As if I really need a lot of heat anyways…
Here is the nasty dime that I found on top of that defog/heat door.
I am surprised it stayed there for so long. It is dated 1972. The other dime was 68 or so.
Makes me wonder when those were dropped in the defog vents. Could it have been a child in his or her first ride when the car was new?? “Oh – big piggy bank slots”!
Little did they know it would be like bank of America - money goes in but not out...
Old Feb 5, 2012 | 11:55 AM
74°?? Sux to live in TX.... You should come up here for some real weather. Actually we can't complain. It was supposed to be the coldest and most snow ever recorded (farmers almanac?) but we've been doing well.
The thread is looking good Rob. It's inspiring me to replace my heater core now too + redo the lower kickpanel vent controls in my non AC car. I think I'll have an easier time getting my heater box out cause it's way less complicated than AC. But the lower side control vents may be a different story. . Have to be careful with everything - I still have OEM carpets and stuff that hasn't ever been out. Actually, BOTH of those h.c. nipples look like they've been crushed. Amazing they lasted this long without flooding the plenum cavity. Are you going to use that 'rope' stuff you used to seal the outer box to the firewall when you reseal the inner?
The AC and heater cable connections look to be the same. I have that same type of bolt/clip on mine. Only a dime in there? I hate stuff that can cause buzzes or rattles. So, now with your 'found money' you can't even get a bottle of soda it used to buy.
I missed the part where you drained the coolant. Since I'm going to re-core my OEM rad I also need to drain mine. What was that comment about blowing out the core? High pressure hose I'm thinking. Anyway, since I'm going to take out the heater box, I might as well think about taking out the dash and installing the options I want there too. I want a MAW helmet - size 7 3/8 please.
I'll do a separate thread for those guys like me who only have a heater in their car.
Old Feb 5, 2012 | 02:10 PM
I would actually prefer a cold winter.
The warmer and humid weather we are having seems to be making a lot of people around here sick. The fungus in the air has kept those with allergies all plugged up and eventually they end up with sinus infections, myself included.
Yes both are deformed. Luckily, any big leaks would drain outside down the firewall.
Yep, got a lot of that rope seal to use between the heater box and core frame. Only problem is if I seal it up too tight, where would it drain should the new core leak?
No, I used my mouth and a section of clean hose to blow it out.
I blew into the top pipe and the old hose on the lower pipe went into a recovery bottle. Worked great - got all but about half a cup out..
Yeow - I will express ship you one tomorrow. They are OSFM but easily trimmable with aviation snips...
Old Feb 5, 2012 | 03:11 PM
  #31
I'm sorry to hear that Rob. Hope you make a speedy recovery. Never really thought about the humidity problems your area has. I hear that Rum & Coke or Rye & Seven is also good to flush out any fungus that might be lingering? I guess soaking in a nice hot bath doesn't really seem to be the answer.
You mean OSFA? No problem. Tell USPS to 'funnel' it my way asap
Old Feb 5, 2012 | 06:04 PM
  #32
Thanks... I am doing better after visiting the doc. He gave me over 40 antibiotic pills to be taking over the next week. This one was bad for sure.
Unfortunately, i cannot consume alky with them. Nor coffee, tea, chocolate, milk, eggs, yada yada. My diet sucks now, but if i get better I will wait...
No, One Size Fits Most. It is a fairly recent size in clothing, due to the soaring sizes of Americans.
Long ago my ex bought a summer robe that was sized OSFM and we both got a laugh out of the "new" sizing. We could almost both fit into it at once. She was too small for it. I think I was even too small. We hated to imagine what what was too big!
When I send the helmet, it will be shipped flat in a plain flat box. If I told the Post Office what it is, the carrier would get it out, assemble it and wear it, just so he did not have to think "I might as well deliver it"...
Old Feb 5, 2012 | 07:31 PM
  #33
pcard's Avatar
70 Cutlass SX
As usual Rob you do a fantastic job of documenting and showing what you are doing.
Old Feb 6, 2012 | 11:20 AM
  #34
You mean the soaring size of North Americans in general.... No that's not what I meant at all. OSFA means "One Size Fits Allan". I'm one of the guilty parties in regards to the 'soaring sizes'. On the good side however I'm not grossly obese; and I could probably lineback with the best of them. Still, I wouldn't mind being 200 again, so I'm controlling my intake a lot, drinking more (health stuff - whatever you want that to be) and am starting a daily physical aerobic routine. I'm life insurance rich, but I always was a sucker for preparing for the worst. My Son and Wife both are supporting my lifestyle change. Dang! Everything I like is on the endangered eating list... Sounds like we all have a cross to bear with something or another.
Old Feb 9, 2012 | 12:14 PM
  #35
Heater box reassembly!
But before I went through all the trouble to do that, I wanted to check the new core for leaks. I have that kind of luck to where I would be the one in a thousand to get a leaky new one…
Basically I put the core in a dishpan half full of water, a hose scrap pushed on the big core pipe, and a bicycle pump connected to the other side of that hose. I held my thumb over the small core pipe and pumped no more than 15lbs into it. I had to repeat a couple times as the hose blew off and I did not want to look for a clamp.
No leaks, so I dried it with the leaf blower and let it sit a few days to dry.
The assembly of the heater box was easy, but I kept bogging myself down trying to find ways to improve the thing…
Doors were checked for looseness and shimmed as needed. Shafts were lubed and any potential air leaks were sealed. Anything that seemed loose was tightened.
A new pipe gasket was cut from some 3/8” plastic closed-cell packing material I had.
A sharp razor knife made easy work of it.
Next, a trial fit of the new core was done. Glad I did this, as there was a big drip of solder on the tank edge RIGHT WHERE the front strap was to be… I carefully ground it down with the dremel, but stopped before I got to the tank.
So now all is ready!
Strip caulk was applied to the core edge, just like the factory did it.
Core was set centered in the frame and straps attached with screws loose. Core had to be adjusted some and then the straps were tightened. Pipes were bent just enough to prevent contact with the frame.
Strip caulk was applied around the box perimeter. RTV might have been a better choice, but what’s done is done.
So now, the core frame was inserted gently into the box. The temp door shaft will need to point straight ahead so it slides in. The 4 screws were tightened but just snug.
Temp door shaft was greased and plastic bushing slid on. Mechanism was placed on and screwed where the screws (and I) had left their marks.
More strip caulk was applied around the air intake. Not sure if it will be beneficial, but could not hurt...
Old Feb 9, 2012 | 12:17 PM
  #36
Done!!
So the box is done and ready for installation!
Defroster parts are not to be installed on the box yet. They are just sitting there for the photos…
One thing is bothering me though...
When you see this symbol on a part, does it mean you are about to be screwed??
This is an outwards impression on BOTH sides of the box, as if there was a screw pressed into the plastic...
Anyone see this before?
Now to look for some underdash work...
Old Feb 10, 2012 | 09:50 PM
  #37
O's_Car's Avatar
Hey Rob, I have one of those in my A/C evaporator case! I wonder what it means...?
Looks like your heater case resto went just like mine; guess I did it right after all! I didn't try to remove the temperature door, but I did drill out the rivets to remove the other backing plate - I wanted to replace the disintegrated foam on that defroster door, plus it gave me an excuse to buy a pop-rivet gun.
I admire your willingness to post detailed threads like this: I don't have the patience to sort and format the photos, download them, and write the descriptions. Keep up the good work!
Old Feb 10, 2012 | 09:58 PM
  #38
It means the AC case prolly came off the same production line where the dufus who left the bolt in the mold worked. How could you get so lucky? I'd like to know if anyone has a case that doesn't have that. Did GM have one central production run for AC cases?
Old Feb 11, 2012 | 04:42 AM
  #39
442_1972's Avatar
Great job on the write up - thanks for documenting these projects like you do.
One comment on the crushed heater core inlet pipe: I've read where the squared off inlet pipe was actually done on purpose as a way to prevent pressure spikes from blowing the heater core. I would think the outlet should not be crimped, however, as that would seem to have the opposite effect (it would cause unwanted pressure buildup in the heater core).
Old Feb 11, 2012 | 09:52 AM
  #40
Not sure, but yours is on the evap box. Mine is on the heater box. Couldn't be a mistake done twice. Or could it??
Here is mine:
Have any pictures of how you did the foam? Not sure if i want to mess with it, since performance is good.
Thanks... It is a lot of work to document this way. However, I am happy when i can help others do their own work for cheap and keep those great old cars on the road. I also enjoy reading them long after and remember what I went through long ago.
Yes, i question who else have these marks and WHERE.
Thanks... Always happy to help!
The crimp at the tips of the pipes are understandable, but the deformations are behind the ridges. A little hard to see int he picture. I am thinking that the damage occured when someone was prying off the old tower clamps...
