Headlights for 1984 Oldsmobile Delta 88
Old Oct 24, 2019 | 10:35 AM
Stephen0523's Avatar
Hello all. Probably a stupid question but my one driver side low beam headlight is burned out. I have never replace them so if anyone has a link to send to me that would be great!
Also does anyone know if it's possible to put high-quality LED bulbs instead of the old-school bulbs?
Thanks in advance!
Old Oct 24, 2019 | 10:52 AM
Pick your poison:
https://www.rockauto.com/en/catalog/...amp+bulb,11701
If you want LED bulbs check it out!
https://www.hagerty.com/articles-vid...r-classic-cars
Old Oct 24, 2019 | 11:31 AM
rocketraider's Avatar
Oldsdruid
LED conversions come with their own set of headaches. You need a 4656 sealed beam. Make sure it has 3 prongs on back.
R&R: you need a #10 or #15 Torx screwdriver to remove the headlight trim and a #2 Phillips screwdriver to remove the headlight retainer ring.
There are 8 Torx screws holding the trim on; make note of which length screw goes where. Remove it and set aside. You can leave the side marker lamp plugged in.
Remove the four retainer ring screws and pull the bulb forward. If those screws have never been out it may take some umph to break them loose. WD40 or PB Blaster and a GOOD heavy screwdriver just in case. DO NOT MESS WITH THE ADJUSTER SCREWS AT TOP AND SIDE OF THE LAMP.
Unplug the old lamp, plug in the new one and then turn lights on both high and low beam before putting it all back together. If the lamp works, reverse procedure and button everything back up.
Word to the wise- newer production sealed beams for our older cars are, to be blunt, not worth a ****. I've recently had a 7-month old low beam burn out and a 2-month old one crack for no good reason. These are Chinese-made Sylvania Halogens. DK what Wagners might do, but they're about all that's available. unless you find an old stock American made one in an older parts store.
Old Oct 24, 2019 | 02:46 PM
CRUZN 66's Avatar
Olds Fever
About 15 years ago I acquired some seal beams from a friend's business when he closed it to move south.. I will have to check them to see it they are marked as to the actual manufacturer... They have been in storage so long I can't recall if they are Sylvania or Wagner... I have several cases of various numbers both round and rectangular...
Old Dec 1, 2019 | 03:23 PM
Got my new lights installed and they are amazing! Will send pics later.
Old Dec 2, 2019 | 07:18 AM
Here are the photos.
These are Grote lights ordered from Bumper to Bumper in Stratford Prince Edward Island.
RG1970
Feb 11, 2016 05:15 AM
1969w3155
Jan 28, 2014 05:33 AM
Fullsizelover
Oct 2, 2013 08:27 PM
Odmark
Jan 14, 2013 12:48 PM
Yellowstatue
Aurora
Jun 17, 2010 03:20 PM
