does a 1984 olds delta 88 have a standard or limited slip differential
im kind of unsure as to which i have, it has a 307 small block 200-c transmission and a 7.5 ring gear differential 2.41 ratio, i was driving in snow eariler i got stuck, when i accelerated the passenger tire was spinning then i heard somewhat of a growling noise from the differential and i saw the driver side tire spinning too, so im wondering as to wether its a limited or standard, as in regular driving conditions only the passenger tire spins, i have to do a fluid change and need to know if its limited or not as i might need the limited slip fluid additive
![Smile](https://classicoldsmobile.com/forums/images/icons/icon7.gif)
If you raise both rear wheels off the ground and spin one of them, if they both spin in the same direction then it has a posi
or if you raise one wheel and try to turn it there will be a certain resistance to overcome the clutch friction (in neutral, brakes off)in a posi diff...a non posi diff will have each wheel spin in opposite directions when both wheels are off the floor...
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
![Cool](https://classicoldsmobile.com/forums/images/smilies/cool.gif)
Ctls442
August 7th, 2015 09:43 PM
1966Oldsmobile
Drivetrain/Differentials
November 24th, 2013 04:10 PM
rickbmac
July 19th, 2008 04:51 PM
