does a 1984 olds delta 88 have a standard or limited slip differential
im kind of unsure as to which i have, it has a 307 small block 200-c transmission and a 7.5 ring gear differential 2.41 ratio, i was driving in snow eariler i got stuck, when i accelerated the passenger tire was spinning then i heard somewhat of a growling noise from the differential and i saw the driver side tire spinning too, so im wondering as to wether its a limited or standard, as in regular driving conditions only the passenger tire spins, i have to do a fluid change and need to know if its limited or not as i might need the limited slip fluid additive
If you raise both rear wheels off the ground and spin one of them, if they both spin in the same direction then it has a posi
or if you raise one wheel and try to turn it there will be a certain resistance to overcome the clutch friction (in neutral, brakes off)in a posi diff...a non posi diff will have each wheel spin in opposite directions when both wheels are off the floor...
Ctls442
Aug 7, 2015 09:43 PM
1966Oldsmobile
Drivetrain/Differentials
Nov 24, 2013 04:10 PM
rickbmac
Jul 19, 2008 04:51 PM
