Coil Springs
maybe somebody knows if this would fit?
http://www.summitracing.com/int/part...commendedparts
The link you sent failed to transfer so I could not see what you were talking about,but I didn't find lowering Springs at summit that said they would fit a '52 Olds. A member here had a picture of his '55 that had been lowered about 3"-4" .He is a registered member and goes by "Rocket Down Under".He has pictures and info about what he did(bagged it). I've known others who removed the coils ,cut 1 round of the springs And that will lower about 2-3". Good luck,Larry
2-3" would be perfect! But do you think the steering still works perfect at 3" drop without scratching the tires on the fenders?
The link shows a 3" drop spindle.
(www.shocks2springs) make springs to modify height of car 2" and sometimes a little more.They specialize in Classic car and truck springs.Phone # 1-800-344-1966 ,or look them up online at the website www.shocks2springs.com. Someone else mentioned "Springs And Things" in Pennsylvania.They show that they make lowering coil,leaf springs,shackles and all. Good luck, Larry
