Car hesitating going up hills.
Old Feb 4, 2014 | 06:10 PM
eddieunderground's Avatar
My car was not getting gas. So I pulled out the fuel pump. One of the diaphragm was ripped. I rebuilt it. No leaks. It runs fine on flat streets. Has a full tank of gas. Has new fuel lines. New air filter. New fuel filter. Does anyone have any more ideas? Could it be the carburetor?
Old Feb 4, 2014 | 06:21 PM
I think we may need more information.
Like, what kind of car, what engine, what carburetor, what modifications, how steep a hill, what throttle level it happens at, repairs, replacements, etc. done so far, for starters.
Old Feb 4, 2014 | 06:29 PM
RROLDSX's Avatar
Water in the gas tank (sits at the bottom of the tank), water in the carb bowl, float adjustment, plug wire touching while going uphill are all possibilites among others.
Old Feb 4, 2014 | 06:37 PM
It's a 62 Dynamic 88. 394 V8. 4 barrel carburetor. Not sure of throttle level.
Old Feb 4, 2014 | 06:38 PM
RROLDSX's Avatar
One other thing I thought of is if the secondary flap is too loose it could be opening
to early under load?
A quadrajet expert might want to chime in on that one.
Old Feb 4, 2014 | 06:48 PM
nsnarsk65cutlass's Avatar
Does it still have the 4gc 4jet carb?Cracked fuel line in back at tank?Whats the fuel pressure when problems occurring?Possible crap in secondary bowl clogging jets,to
low secondary float level?
Old Feb 4, 2014 | 08:11 PM
Is there fuel getting to the carb from the pump?
Old Feb 4, 2014 | 11:21 PM
The car runs fine on flat streets. Gas is getting to the ccarburetor.
Old Feb 5, 2014 | 12:22 AM
What carburetor?
Old Feb 5, 2014 | 08:11 AM
D. Yaros's Avatar
If the fuel pump diaphragm was "ripped," then maybe you now have a clogged fuel system at some point after the fuel pump?
cutlassgal
Jul 16, 2012 05:50 AM
cutlassgal
Jul 12, 2011 10:12 AM
extreme1
Jun 7, 2010 07:14 AM
ztim
Sep 13, 2008 01:59 PM
82 88 45
Dec 23, 2006 06:42 AM
