Build Sheet located!
Old May 11th, 2009, 06:02 PM
radioburningchrome's Avatar
The 65 Delta has not run in 10 months. Cleaned the neutral safety switch connectors and it fired right up.
Saw a mouse running around the interior and leaving "presents" everywhere. Pulled out the seats and found the build sheet under the top half of the rear seats.
Never had a 2.93 gear. It has to be better than the anemic 2.73, but not by much.
radioburningchrome is offline
Old May 12th, 2009, 04:38 AM
Past Administrator
Oldsguy's Avatar
Excellent, and yours is in good shape. About the mouse, a company field service tech found a nest in the glove box of his new 2009 Chevy Traverse service truck. The mice had used the pink slip for material, it was almost halfway eaten up, all shredded for bedding material. If they can find them in a brand new vehicle, we are lucky to find those build sheets after 30 plus years and in such good condition.
Oldsguy is offline
Old May 12th, 2009, 04:41 AM
Great find
Try putting Bounce dry sheets under the seat. It helps keep the critters out.
Jamesbo is offline
Old May 12th, 2009, 05:40 AM
Dryer sheets were all over the car. No effect (Bounce)!
Critter even shredded up aluminum foil.
Old May 12th, 2009, 06:08 AM
Trying to remember member
wmachine's Avatar
My favorite piece of documentation!
wmachine is offline
Old September 26th, 2009, 09:17 PM
gregc's Avatar
I found mine in the drivers door panel when I took it apart to replace some missing screws on my 75 Royale Convertible.
gregc is offline
Old September 27th, 2009, 07:20 AM
Strange place.
I have always found mine under seats or the dash.
marxpups
December 3rd, 2011 01:15 PM
jensenracing77
June 16th, 2011 03:14 PM
skip79
March 1st, 2010 08:54 AM
ozoneblue
June 4th, 2009 09:13 AM
Quick Reply: Build Sheet located!
