brake rotor UPDATE FOR 69/70
Old Sep 17, 2013 | 09:52 PM
russell7088's Avatar
Yes 2000 camaro are gonna work, all the dimensions are right there wth minmal difference, I will be contacting a machine shop to have a set bored out in the center and the bolt pattern changed. I will go back to all of our threads about this and compare the suggested rotors to this and see if any other are this close..
Old Jan 9, 2014 | 09:57 AM
sqeeek's Avatar
That's very good to know. Thanks.
Old Jan 24, 2014 | 09:29 PM
oldsmobilty's Avatar
Has anyone taken the rotors off of a 96 Chevy pick up in consideration, or took measurements for fitment?
Old Jan 25, 2014 | 09:52 AM
sqeeek's Avatar
Something like this? Within the next month or two, as soon as the ground in the pick-a-part places isn't slushy anymore, I'll find one and take a look.
Old Feb 3, 2014 | 11:45 PM
yes i have done it wont work, if you search old posts about this Joe Padavano i think i spelled that right posted a bunch of measurements of different rotors that were close but none were as good as these camaro
Old Feb 3, 2014 | 11:56 PM
Bernhard's Avatar
Are the rotors no longer available?
Old Feb 4, 2014 | 01:23 PM
cfair's Avatar
Can you have your machine shop make a template or instructions for the bolt pattern change and the boring instructions so the rest of us can have some made up as well?
This is a big leap if we can get there, many thanks.
As an aside, what brake booster and year of master cylinder are you going with? I like the translucent ones from the 80's/90's, but am unsure what bore for a disc/drum set up would be right.
cheers,
cf
Old Feb 6, 2014 | 07:03 AM
cheers,
cf
yes i will, sorry I have been slacking on getting it done actually bought another delta also.
My olds or actually both of my cars have disc brakes already so i am gonna use the factory stuff
Old Feb 6, 2014 | 07:04 AM
No rotors are not readily available at all for these cars
Old Feb 6, 2014 | 05:50 PM
68 D88's Avatar
The 96 Chevy rotor is not going to work. There is no rotor that is closer dimensionally than the 2000 camaro. I've looked at many different ones including the later Chevy truck 5x5. The camaro rotor will work with minor machining. Over bore the center hole to the olds hub dimension and add the 5x5 lug pattern between the existing lug pattern and press the lugs back in.
Old Feb 10, 2014 | 04:12 AM
should be an easy upgrade also since there are alot of options out there to upgrade the camaro
Old Mar 29, 2014 | 06:10 AM
cfair's Avatar
Any update on Camaro rotors for 65-70 big cars?
brown7373
Sep 12, 2014 06:51 AM
Rocketbrian
Brakes/Hydraulic Systems
Jan 21, 2014 07:14 PM
bgarrett
Feb 25, 2012 11:49 AM
onetogofast
Jul 14, 2011 09:58 AM
bobb
Oct 13, 2010 04:23 PM
