Blower resistor
Old September 6th, 2011, 10:40 AM
BStone's Avatar
Blower resistor
OK, so have been tearing apart the blower system to figure out what the problem is with my 67 Olds Delta 88. After de-fu&*ing the POs wiring bypass, I have pulled the blower ersistor and see that it is torched ie one of the coils is broken.
Can someone tell me where to find one of these or if there is a comparable part out there out of something a bit more modern? The local NAPA crew etc can't seem to find anything
Thanks!
BStone is offline
Old September 6th, 2011, 06:47 PM
Lady72nRob71's Avatar
Can you post a picture of your old one? maybe we can match up something
Lady72nRob71 is offline
Old September 6th, 2011, 07:10 PM
BStone's Avatar
Here they are. The car has A/C
BStone is offline
Old September 7th, 2011, 01:12 AM
'87 Delta 88 Royale
rustyroger's Avatar
I made my own resistor pack for my '79 Olds Delta, 2 4ohm resistors from a local electronics store and 1/2 hour with a soldering iron, you will need 3 resistors.
I cant get parts easily over here, I'm surprised you have trouble finding them though.
Roger.
rustyroger is offline
Old September 7th, 2011, 09:50 AM
BStone's Avatar
I don't mind soldering up some resistors but do you know what the three resistances would be for a 67 delta?
ie is it just a case of 3 x 4 ohms resistors in series? The wire spools seems to imply that they each woudl have a different resistance.
BStone is offline
Old September 7th, 2011, 01:22 PM
Hangin' out...
henryk8398's Avatar
Roger.
Roger, awesome solution! I'm just beginning to tinker with electronics myself, so I'd love to see a picture of that your solution looks like! I'm sure others would, too. I assume the resistors you used were heavier duty?
Bstone, grab a multimeter and measure the resistance of the intact coils first. For the broken coil, try use something non-conductive to hold the broken leads together (coated paper clip, tape, etc). You should be able to measure the resistance. That should tell you what resistors you would need for each speed setting.
henryk8398 is offline
Old September 7th, 2011, 01:46 PM
BStone's Avatar
The manual shows the wiring for a non-ac variant as having a 32 and 70 ohm resistor (34, 36, and 38 series) so that will cover 2 out of 3 of them including the broken one. Note that it doesn't list the actual resistances for a 52-86 series but I would think they would be the same.)
For the a/c connector I will mulitimeter it.
BStone is offline
Old September 7th, 2011, 04:34 PM
If using electronics store resistors, make sure the wattage is high enough to avoid the release of the magic smoke...
Old September 7th, 2011, 04:59 PM
Beware, the A/C motor is bigger and probably draws more current and uses different resistances.
Best bet is to measure what you've got, and if you can't tell how big to make the resistors, just use Ohm's Law to figure out the current through your resistance at 14v (V/R=I). If the current is higher than the specified fuse, use the rated fuse current (or a bit higher).
The resistor will probably be large and ceramic-cased.
One way to measure the resistance of the bad coil(s) is to measure resistance from terminal to broken end A, and then from opposite broken end B to other terminal and add the values.
You don't have to get a resistor that's exact, just one that's close, as long as it's rated high enough (probably about 20 amps).
You can just snip out the burned or broken bits and solder in the replacement resistor where the old coil(s) used to be.
MDchanic is offline
Old September 7th, 2011, 08:49 PM
Lt. Buzzkill (ret.)
copper128's Avatar
I found a NOS one on eBay for my 67.
copper128 is offline
Old September 7th, 2011, 10:58 PM
Lt. Buzzkill (ret.)
copper128's Avatar
Look for part #387519 for manual AC or 397196 for Tempmatic.
OldsObsolete.com shows both in stock for $65 and $85 respectively. Pricy, but if you need one...
http://app.vendio.com/storefront?foo...3531312&mode=1
http://app.vendio.com/storefront?foo...8809958&mode=1
Old September 8th, 2011, 01:58 AM
'87 Delta 88 Royale
rustyroger's Avatar
The current to the fan runs through all resistors for the lowest speed, and as you turn the fan speed up it bypasses the resistors in sequence, full speed is when the current goes direct to the fan.
My Olds was non A/C btw, the resistor unit had fallen apart and I guessed at the values needed, I measured the resistances on a Nissan unit and used the same values. I'm not saying I got it exactly right but it worked.
I told the clerk at the electronic store what I intended to use the resistors for and he made sure I had what I needed. Just like when I find a good auto parts clerk this store gets my business now and I tell others who ask where I found good knowledgeable service.
Roger.
Old September 8th, 2011, 09:23 AM
BStone's Avatar
Wow...outstanding info guys. I picked up a resistor off an 80's Buick (part 526897) for $3 so will see how it works with some light "mods"
BStone is offline
redvettemike
September 6th, 2010 07:06 PM
MJAKS462
July 22nd, 2010 03:44 PM
mmcilroy
January 25th, 2010 04:03 AM
Texas67olds
November 1st, 2009 12:59 PM
jeffreyalman
May 20th, 2009 01:13 AM
Quick Reply: Blower resistor
