anyone ever change a rear seal without pulling the engine?
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
this is on a 1958 371
My rear seal is leaking, I figured I'd change it out. Jacked up the car, drained the oil, pulled off the lower flywheel cover. pulled all bolts out of the oil pan. but the pan won't pull out. the exhaust cross over is in the way. I thought about pulling it, But I don't want to pull it to find out that the steering rod (for the tie rods) may be in the way.
Has anyone successfully dropped the oil pan with out pulling the engine. Or am i making a trip into town to buy an engine hoist?
![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
On a 55 you can squeeze the pan down and to one side by unbolting the motor mounts and jacking the motor up till it hits the firewall and if you are a contortionist with tiny fingers you can do it. The last one that was installed in my car went in that way, but not by me who has fat fingers and can't touch his toes. A neoprene gasket was used, may be harder with a rope seal I don't know....Tedd
When I was younger I did a few, but no Olds. Messy and dirty. There used to be some special tools for this, made by Lisle I think. They had a chinese finger sort of puller to work the upper rope in. Unless the leak is extreme I wouldn't do it. Of course I had no lift.
X2 on reading the manual.
In one of the post above ,a Chinese finger type of puller was mentioned.It was known as a
"Sneaky Pete" and I believe they are still available online. Just google "Sneaky Pete" Rear main seal tool. Larry
Tedd,the "Slim Jim" that I remember was Oldsmobile's least popular transmission in most of our opinions.The "sneaky Pete " on the other hand was a very useful tool in the past to save time, and make it possible to repair rear main leaks without removing the engine.Don't worry,I think we all have a little case of "sometimers" at times ,I know I'm guilty. Larry
I ended up just changing the lower half. the groove walls are more "dove tailed" then straight walls, so feeding the rope around was not going to work, had to press the rope into the groove on the cap.
But seems to have worked, ran it for a minutes last night, no leak. Taking it into town today, see what happens.
I was surprised, the oil pan had very little sludge build up. the back main lower half looked like new, never pulled the upper half. The cranks shaft looked and felt great as well. really good shape. The oil pump screen was dirty and needed cleaning. outside of that, its in great shape.
Replaced one on a 283 chevy years back. You have to turn the crank as you pull the chinese handcuff tool with the rope seal in it. Then you have to trim the seal with a razor blade flush with the block. A two man job and not too much fun.
MDchanic
31
August 12th, 2012 04:24 AM
ChefDeadpool
37
May 23rd, 2012 08:32 PM
Aceshigh
September 29th, 2010 10:31 PM
xxibishn
September 14th, 2006 01:11 PM
