85 Delta engine swap
You bet your *** they will. Bolt some 307 motor mounts to the 455 block, and you're good to go.
Big block headers for 73-76 cutlass will bolt in too if you remove the front frame braces. you will have to dimple them 1/4'' by the lower control arms and grind off the bottom firewall lip.
Also, I noticed that your sig says you have a royale, and not a royale brougham.
If your car is a 2 door royale, there were only 15,002 made in 85'.
The 2door royale broughams were 31,891.
4dr royale--69641
4dr royale brougham--102,342
If you have the overdrive trans, you will have to get the crossmember from a 200c car to use with the th350
if you want to use a th400, you will need driveshaft modifications. Th400 uses 32 splines, instead of 27
4dr royale--69641
Or, you can use the crossmember you have with a TH400. The mount location for a short tailshaft TH400 is in the same location as on the 200-4R. You will need a shortened driveshaft with the correct front yoke.
4dr royale--69641
4dr royale--69641
'69CutlassVert'
August 25th, 2011 07:19 AM
