85 Delta engine swap
Old Feb 24, 2009 | 08:07 PM
whizkid88's Avatar
Will a 455 slip right into the mounts from the old 307?
Old Feb 25, 2009 | 02:43 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
You bet your *** they will. Bolt some 307 motor mounts to the 455 block, and you're good to go.
Big block headers for 73-76 cutlass will bolt in too if you remove the front frame braces. you will have to dimple them 1/4'' by the lower control arms and grind off the bottom firewall lip.
Old Feb 25, 2009 | 05:10 PM
whizkid88's Avatar
Thanks man. I would also like to know what I have to do to the crossmember to put a 350 or a 400 tranny behind it.
Old Feb 25, 2009 | 07:30 PM
If you have a 200c metric transmission without overdrive, a short tailed th350 is a direct swap. You will just have to add a metal vacuum line for the modulator.
Old Feb 25, 2009 | 07:49 PM
Also, I noticed that your sig says you have a royale, and not a royale brougham.
If your car is a 2 door royale, there were only 15,002 made in 85'.
The 2door royale broughams were 31,891.
4dr royale--69641
4dr royale brougham--102,342
If you have the overdrive trans, you will have to get the crossmember from a 200c car to use with the th350
if you want to use a th400, you will need driveshaft modifications. Th400 uses 32 splines, instead of 27
Old Feb 26, 2009 | 04:01 PM
whizkid88's Avatar
Yes, it happens to be a 2 door coupe and it has the 200c w/ overdrive.
Is there any way to get around getting a new crossmember?
And actually this car is one of the first built in 85.
Old Feb 26, 2009 | 05:00 PM
200c does not have overdrive.
2004R is the overdrive trans.
If you have the 2004R, you will need to go get a different X member from a non overdrive 80-85 Lesabre, or Delta 88.
Old Feb 26, 2009 | 05:36 PM
whizkid88's Avatar
Ok I will see if i can find one. Oh I cant wait until i get the new engine and tranny.
Old Feb 26, 2009 | 07:20 PM
You might also consider building the 200 4R you have. It will bolt up to your 455 but will tank the first time you step on it unless you build it.
Old Feb 26, 2009 | 07:45 PM
Or, you can use the crossmember you have with a TH400. The mount location for a short tailshaft TH400 is in the same location as on the 200-4R. You will need a shortened driveshaft with the correct front yoke.
Old Feb 26, 2009 | 08:18 PM
easytobedead's Avatar
Just A BaBy {:
4dr royale--69641
thats some good info!
deltaskelta
Nov 21, 2012 06:41 AM
Fastdelta88
Non-Olds Engines
Nov 4, 2012 08:45 AM
805cut
May 3, 2012 08:11 PM
'69CutlassVert'
Aug 25, 2011 07:19 AM
oldsmobum
Jan 14, 2011 10:10 PM
