'73 Delta88 Diff Identification blank??
Acceleratii maxim rapidus
I'm trying to identify all the bits on my '73 delta and have drawn a blank IDing the diff. I've looked at the tech pages but can't find any info that relates to my '73 Olds.
The codes stamped on the diff (location found on the tech pages) are;
KA B283 1
the diff has a 10 bolt rear cover.
If possible I'd like to find out the size, type, gear ratios and whether or not its a posi diff. ( I dont think it is but hey, you never know!)
Can someone help? Thanks for your replies.
KA B283 1
OK, looking at the codes in the 73 service manual (sect 4B-33), there is no KA code shown for a Delta 88.
However I'm gonna take a stab at this and say what you have is probably a 2.73:1 open 8-1/2" 10-bolt.
I'm guessing the K indicates an open diff 8-1/2" 10-bolt
the A in the 2nd position is consistent with a 2.73 ratio in all differentials used in the larger cars
Here's a link to a scan of the differential ID page from the service manual:
http://tinypic.com/m/i2t0nn/4
Just from my experience, two 1971 Delta 88's both 455 v2, each had the 8 1/2 corporate. One 1971ninety-eight but it was a 455 v4, it had the larger 8 7/8 gears. Was it because the 98 was heavier or the 4 barrel? Ken
Thanks Kennybill for the info. How do I tell if its a v2 or v4 455 and whats the difference? It has the 4 barrel carburetor option.
Here are the diff pics. The last one came out reversed for some reason.
Thanks for the pics.
As I suspected, the squared-off lugs underneath and the 2 parallel ribs on the side of the housing positively ID it as a corporate 8.5" 10-bolt.
And 4-bbl carburetor means exactly the same as 4v carb. The "v" is an abbreviation for "venturi".
Maybe just the "heavier" cars (98's) got the larger 8 7/8 rearend. Was your a factory 4 barrel 455? Actually your lucky because different gear ratios are available for your rearend. The bigger one not so much. Ken
barquecat
February 12th, 2008 07:12 AM
