65 66 67 OLDSMOBILE F85 CUTLASS 88 REMAN 2BBL CARB
Old December 14th, 2008, 10:31 AM
65superrocket's Avatar
Hello new to the site. Was looking at a remanufactured carb on e-bay as a spare and was wondering if any one knew what the tube coming out the top side of the carb throat is. My original 2G Rochester does not have this. My car is a 65 OLDS DELTA 88. 425 HI COMP ENGINE.Here's the link. Thanks.
http://cgi.ebay.com/ebay motors/NEW-65-66-67-OLDSMOBILE-F85-CUTLASS-88-REMAN-2BBL-CARB_W0QQcmdZViewItemQQ_trksidZp1713Q2em153Q2el126 2QQcategoryZ33550QQihZ026QQitemZ390016604489QQtcZp hoto
65superrocket is offline
Old December 14th, 2008, 10:39 AM
Ca's Only Official OLZNUT
66 Olznut's Avatar
Looks like a float bowl vent tube to me......
66 Olznut is offline
Old December 14th, 2008, 11:22 AM
Danny Wiseley's Avatar
I see the bowl vent tube (with angle cut) too. Are you referring to the short tube with the black cap on the rear of the carburetor? That's a "clean-air" tap for the choke. Air is drawn from that connector through the tubing in the choke stove in the manifold, then over the bimetallic spring in the choke housing by a vacuum passage behind the spring.
DW
Last edited by Danny Wiseley; December 14th, 2008 at 12:21 PM. Reason: To complete reply after interruption. . .
Danny Wiseley is offline
Old December 14th, 2008, 01:54 PM
Yes, it's the tube at the back of the carb with the black cap. So this is a clean air intake pipe for the choke? My original carb does not have this. The choke stove pipe and plate connect to the intake manifold then to the choke. Is anythng suppose to connect to this fresh air pipe? or is it just a vent to draw air in? Thanks.
Old December 14th, 2008, 09:21 PM
The later models used that connection as a source of clean air for the choke. The air flows out through that tube, down to the choke stove, then up to the choke coil, then through the port leading to vacuum below the butterflies.
Old December 15th, 2008, 05:52 PM
If I leave the cap on this pipe can I connect this carb as my original is connected with the threaded stove fitting at the choke? Thanks.
April 23rd, 2020 09:16 AM
auto_editor
June 15th, 2012 05:27 PM
boese1978
April 23rd, 2012 07:46 AM
L69
December 25th, 2011 08:12 PM
ZASX
November 19th, 2007 04:34 PM
Quick Reply: 65 66 67 OLDSMOBILE F85 CUTLASS 88 REMAN 2BBL CARB
