65 66 67 OLDSMOBILE F85 CUTLASS 88 REMAN 2BBL CARB
Old Dec 14, 2008 | 10:31 AM
65superrocket's Avatar
Hello new to the site. Was looking at a remanufactured carb on e-bay as a spare and was wondering if any one knew what the tube coming out the top side of the carb throat is. My original 2G Rochester does not have this. My car is a 65 OLDS DELTA 88. 425 HI COMP ENGINE.Here's the link. Thanks.
http://cgi.ebay.com/ebay motors/NEW-65-66-67-OLDSMOBILE-F85-CUTLASS-88-REMAN-2BBL-CARB_W0QQcmdZViewItemQQ_trksidZp1713Q2em153Q2el126 2QQcategoryZ33550QQihZ026QQitemZ390016604489QQtcZp hoto
Old Dec 14, 2008 | 10:39 AM
66 Olznut's Avatar
Ca's Only Official OLZNUT
Looks like a float bowl vent tube to me......
Old Dec 14, 2008 | 11:22 AM
Danny Wiseley's Avatar
I see the bowl vent tube (with angle cut) too. Are you referring to the short tube with the black cap on the rear of the carburetor? That's a "clean-air" tap for the choke. Air is drawn from that connector through the tubing in the choke stove in the manifold, then over the bimetallic spring in the choke housing by a vacuum passage behind the spring.
DW
Last edited by Danny Wiseley; Dec 14, 2008 at 12:21 PM. Reason: To complete reply after interruption. . .
Old Dec 14, 2008 | 01:54 PM
Yes, it's the tube at the back of the carb with the black cap. So this is a clean air intake pipe for the choke? My original carb does not have this. The choke stove pipe and plate connect to the intake manifold then to the choke. Is anythng suppose to connect to this fresh air pipe? or is it just a vent to draw air in? Thanks.
Old Dec 14, 2008 | 09:21 PM
The later models used that connection as a source of clean air for the choke. The air flows out through that tube, down to the choke stove, then up to the choke coil, then through the port leading to vacuum below the butterflies.
Old Dec 15, 2008 | 05:52 PM
If I leave the cap on this pipe can I connect this carb as my original is connected with the threaded stove fitting at the choke? Thanks.
Apr 23, 2020 09:16 AM
auto_editor
Jun 15, 2012 05:27 PM
boese1978
Apr 23, 2012 07:46 AM
L69
Dec 25, 2011 08:12 PM
ZASX
Nov 19, 2007 04:34 PM
