61 Dynamic 88 wiper switch
Old May 23, 2018 | 08:34 AM
delta70's Avatar
A friend of mine has a 1961 Dynamic 88 and wants to take the wiper switch out of the dash (sits in a pod on the left side of the dash with no access from behind) does anyone know how to remove it?? thanks
Old May 23, 2018 | 01:16 PM
Oldsfan's Avatar
You will have to remove the A-pillar garnish molding in order to access the hidden screw for the left side dash panel. There are two more screws at the bottom. One is toward the front and screws into the main dash panel. One is by the door opening and may be hidden by the cardboard kick panel. In that case, you'll have to remove the left hand vent screen and then remove the kick panel. After all three screws are removed from the side panel, the panel can be pulled away from the dash and the switch removed.
Old May 24, 2018 | 07:07 AM
delta70's Avatar
Thank you Oldsfan, I will pass the info to him.
Old Jun 20, 2019 | 08:29 AM
Wife is a Hippie!'s Avatar
62 Dynamic 4dr hard top
Is it the same for a 62 dynamic?
lemoldsnut
Jun 9, 2018 09:56 AM
Bobac455
Jul 29, 2016 09:44 AM
chip-powell
Sep 6, 2015 07:17 PM
brown7373
Jan 19, 2011 05:32 AM
71cutlasshardtop
Sep 19, 2007 08:01 PM
