57 /58 371
Old January 19th, 2009, 08:43 PM
Bosco1956's Avatar
57 /58 371
I think I saw somwhere that the 57 and 58 371 was externally balanced If that is correct were they done like Chevys with the dampner & flywheel
Bosco1956 is offline
Old January 20th, 2009, 08:27 PM
Junior Member
88 coupe's Avatar
Yes and yes.
If you are using a 303/324 trans behind a 371, have the early flywheel transfer balanced to the late one, and use the late damper. For 12 volts, use a '53-'55 (or '56 Hydro) starter to match the flywheel.
Norm
88 coupe is offline
Old January 21st, 2009, 10:09 AM
Bosco1956's Avatar
Thanks Norm
<GuitarGuyBlue>
September 26th, 2018 08:06 AM
<rainh8r>
August 11th, 2004 06:45 PM
Lobo
June 29th, 2004 09:05 PM
Quick Reply: 57 /58 371
