1984 Oldsmobile delta 88 power steering leak
Old May 29, 2015 | 10:26 AM
matteo024's Avatar
I have an 84 delta 88, and it has sat for eight years, I recently restored the car so it is running but not sure what it needs to pass safety. The car runs and drives but I have no clue why it leaks, also I want to improve HP on the current 307 any ideas?
Old May 29, 2015 | 07:28 PM
Most power steering leaks are hose related.
Old May 29, 2015 | 07:36 PM
Octania's Avatar
visual inspection is a good way to spot a leak. Spray the area with brake cleaner to remove most leakage, then operate the system briefly and look for fresh juice. Follow it up and forward until you find the wet spot, typically pressurized. Check the hose connections for tightness and the hoses for aging, cracks, etc. Leaks at crimped ends.... High pressure crimped end is most likely.
Old May 30, 2015 | 06:53 AM
Actually, on several of my 1980s cars, the leak has been due to the front seal on the pump. As Chris points out, figure out where the leak is coming from then replace the offending parts. Everything is readily available.
Old May 30, 2015 | 01:56 PM
matteo024's Avatar
Okay I'll try that out, one of my exterior belts is squeaking, what should I look for to fix this ?
plonka
Mar 8, 2015 06:28 PM
76 Regency
Apr 4, 2014 07:11 PM
Perry615
Apr 16, 2013 05:55 PM
sweet70oldz
Brakes/Hydraulic Systems
Jun 30, 2012 01:21 PM
84oldsDelta88
20
Apr 20, 2010 01:46 PM
