anyone ever rebuild their own speedometer?
Old May 31, 2015 | 09:24 AM
RXN's Avatar
RXN
My speedometer has always clicked, and the needle would bounce back and forth. This was more so at slow speeds, once over 60 it would smooth out and hold steady.
I replace the cable thinking it was the cable end. nope that did not fix it. Spraying liquid graphite at the speedo head would give the speedo about an hour or two of smooth operation before it would start clicking and bouncing again.
Yesterday, she clicked her last click and died. and when the needle quit so did the odometer. I rely on my odometer for when to fuel up again, as the gas gauge doesn't work.
I pulled the cluster out of the dash last night. I found the shaft that the cable turns to be seized, this drives both the speedometer needle and the odometer gears.
I freed it up. cleaned the bore (no bearing) and greased the shaft. it spins good now.
With just the speedometer parts. (odometer and gears removed) i can get the needle to work about 70% of the time, when i think I've finally got it and I attache the odometer and put the gear back in, the speedometer needle does not move, but the odometer works fine.
Any ideas? How does that shaft rotor spin that (brass/bronze) housing for the speedometer?
thanks
Old May 31, 2015 | 10:42 AM
oldspackrat's Avatar
What year & kind of car do you have?
Old May 31, 2015 | 11:10 AM
RXN's Avatar
RXN
it is a 1958 Dynamic 88.
Old May 31, 2015 | 11:13 AM
RXN's Avatar
RXN
I pulled the speedometer/Odometer out of my parts car. of course the numbers are faded. so ended up swapping the odometers. then added the missing milage. I went 98miles since it quit. Thank god for google maps. so I was able to put the reading back to where it should be.
I'm going to have to send the old one out for repair.
Old May 31, 2015 | 11:46 AM
Octania's Avatar
thanks
Either it works 100% of the time or it is not working....
Not real familiar with 1950's speedos but in the ones I have dismantled, the cable spins a magnet which is coupled to the driven part by magnetic action. Even though the driven member is nonferrous. Same principle on which AC motors work. Same thing if you drop a magnet into a Cu or AL pipe.
Old May 31, 2015 | 12:31 PM
I've done this trick for many friends. Eddy currents & magnetism in general is crazy magic stuff.
Old May 31, 2015 | 04:43 PM
RXN's Avatar
RXN
I gave up and took the one out of the parts car.
will have to send the old one for a rebuild.
Old Jun 1, 2015 | 12:31 PM
rustyroger's Avatar
'87 Delta 88 Royale
I made a good speedometer out of two old units for a '59 Cadillac a few years ago. I painstakingly took them apart and built one up with the best or still working parts and it was fine.
A very fiddly job, around the same time I found I needed glasses for reading!.
Roger.
w-30dreamin
Oct 11, 2013 08:35 AM
ddx77
Jan 25, 2012 11:24 AM
Aceshigh
Jan 5, 2012 08:17 PM
Klayfish
Jun 9, 2011 10:39 AM
Aceshigh
Jul 22, 2009 01:36 PM
