1970 distributor dwell specifications
Old Feb 28, 2010 | 04:52 PM
Prsabordo's Avatar
Does anyone know where i can find the specs for setting the dwell on a 1970 88 with 455 and 2bbrl?
Old Feb 28, 2010 | 05:13 PM
Destructor's Avatar
30 degrees
Old Feb 28, 2010 | 06:13 PM
Prsabordo's Avatar
thanks, is there a way to check the dwell without actually having the car running? My dad's delta won't even run at idle properly. we did a complete tune up with plugs, cap, and rotor and it won't run right even if at all. i did a rebuild on the carburetor a couple months ago but we realized that after awhile of trying to start it, fuel starts leaking through the bowl and main carb gaskets. My dad thinks its the carburetor and i think its the ignition timing. Any ideas?
Old Mar 1, 2010 | 03:37 AM
Destructor's Avatar
How old are the points? also condenser. Unless you know they have been recently replaced, replace them both.
Old Mar 1, 2010 | 09:24 AM
Prsabordo's Avatar
The points on the cap of the distributor? Also what condensor?
Old Mar 1, 2010 | 12:21 PM
svnt442's Avatar
The condenser is the small canister looking thing usually strapped to the coil. The points are inside the distributor.
Old Mar 1, 2010 | 12:36 PM
Prsabordo's Avatar
Im confused with the points. Aren't they on the inside of the distributor cap?
Old Mar 1, 2010 | 02:19 PM
svnt442's Avatar
Yes under the rotor.
Old Mar 1, 2010 | 02:59 PM
Prsabordo's Avatar
got it, found it and replaced it. Turns out that was the problem. The point set was down to bare metal. Runs like a champ now. Thanks for the help guys.
Old Mar 3, 2010 | 02:38 PM
Prsabordo's Avatar
Just to be clear, you check the dwell setting first, then check timing on the crank with the timing light, right? and for sure it is 30 for the dwell specs? Does anyone know what the vacuum pressure should be on the 2brrl rochester carb on a 455?
69442murph
Nov 12, 2011 08:45 PM
pcard
Oct 2, 2011 01:26 PM
ChefDeadpool
Dec 14, 2010 01:08 PM
Pfiffle
Mar 16, 2008 10:10 PM
dynamic88builder
Nov 25, 2005 08:31 PM
