1967 Delta 88 steering box sloppy
Old Jan 18, 2025 | 05:51 PM
2170mark's Avatar
I have a 67 Delta 88 sedan. The steering gear box wanders. Also needs no effort to steer. 100 % power assist. The front end parts seem tight. I’ve put radial tires on it. Car makes you constantly compensate for wander. Is there a fix or a steering gear box upgrade?? Any suggestions?? Car has 81k original miles with 425 4 barrel engine.
Old Jan 18, 2025 | 06:20 PM
Obviously check the steering box for wear. Also, check the alignment. Factory settings on these cars was near zero caster. This made for easy steering, even with a manual box, but hurts tracking and straight-line stability. The biggest difference in new car steering geometry is the caster setting, typically 4-7 degrees. Since every new car comes with power steering, this is no longer an issue. I've managed to crank in about 2.75 degrees of caster on my 67 Delta, but that's the limit with the stock upper control arms.
Old Jan 18, 2025 | 06:34 PM
2170mark's Avatar
Old Jan 18, 2025 | 06:37 PM
2170mark's Avatar
Might you know the factory alignment specs so I have a starting point??. I know the steering wheel is off a bit. So I expect toe to be off to some degree. Thx for guick response 👍
skekas33
Suspension & Handling
Dec 24, 2022 06:35 AM
The_German
Sep 18, 2022 10:27 AM
65Delta88
Dec 27, 2010 08:03 AM
agtw31
Apr 22, 2010 07:46 PM
65Delta88
Dec 1, 2008 05:36 AM
