1964 Olds Dynamic
Old Sep 4, 2007 | 09:35 PM
traviss061986's Avatar
Exclamation 1964 Olds Dynamic
HELP!!!! I cant find a fuel pump anywhere for this car.. Its been sitting in the tow yard for 2 weeks because they claim "they cant find the pump". Well, Ive been looking online for 2 hours now and havent found anything.. Does anyone have any suggestions?
Old Sep 5, 2007 | 01:38 AM
dynamic88's Avatar
usa parts has them for the 64 all v8 300 and 330 engines for $38.58. www.usapartssupply.com 1-800-872-2013. might also check with www.nosgm.com. im surprised that your local auto parts store cant get them. if those dont work you might pick up a hemmings catalog and go through the section covering oldsmobiles. im sure you could find something there. chris
Old Sep 5, 2007 | 04:25 PM
88 coupe's Avatar
Junior Member
Originally Posted by traviss061986
........ I cant find a fuel pump anywhere for this car ........
Easier to get a rebuild kit from Egge Machine and rebuild the one you have.
Originally Posted by dynamic88
........ im surprised that your local auto parts store cant get them ........
For a 394?
Norm
Old Oct 31, 2007 | 08:00 PM
Kaline's Avatar
It sounds like you need to get the car running in a hurry...I would buy a universal electric pump that you could mount to the frame near where the factory mechanical fuel pump is. With a power signal switched on by the ignition and a ground, you would be back in business. NAPA and other larger automotive stores sell pumps like this. Just be sure it does not supply too much pressure...I would guess a factory carb would not like more than 8-9psi (just my own guess).
Best of luck.
Old Nov 1, 2007 | 05:03 AM
Oldsguy's Avatar
Past Administrator
Put the electric pump back near the fuel tank, electrics push not pull. And put a switch in the 12 volt line to the pump for safety purposes.
Old Nov 1, 2007 | 02:57 PM
Kaline's Avatar
I forgot that electric fuel pumps push. OldsGuy is correct - mount the electric pump near the tank.
Old Nov 1, 2007 | 05:21 PM
Check out Fusicks and Kanter. They will probably also have what you want. Also, I have heard good things about the rebuild kits for mechanical fuel pumps. I have never used one of the rebuild kits, but a mechanical fuel pump is a simple device. I don't think it would be too difficult.
Old Nov 17, 2007 | 09:28 PM
Kaline's Avatar
Fusick's lists the correct fuel pump for your '64 in their catalog. A few other places to call are:
Arizona Vintage Parts 800-433-977
GM Obsolete 602-253-8081
Terrill Mechine 254-893-2610
Best of luck.
Old Apr 10, 2008 | 09:11 PM
convertible's Avatar
try fusick.com and go to download catalog
Old Apr 11, 2008 | 09:17 AM
rocketraider's Avatar
Oldsdruid
You need to be sure and get one that has been rebuilt with materials that tolerate modern fuels. Otherwise the diaphrams will disintegrate very quickly. Stay away from high-priced NOS units for the same reason.
Old Apr 11, 2008 | 10:23 AM
KQQLCAT's Avatar
What motor is in your car I might have one if it's a 394 and does not need the vacuum part. I bought it by mistake when looking for one for my 61 with delux heater.
Pat
Cisco5553
Apr 26, 2014 10:08 AM
bccsrc
Feb 6, 2012 07:05 AM
rbanks40
Cars Wanted
Jun 9, 2011 02:27 PM
fastvan67
Apr 19, 2007 05:14 PM
MWS88Dynamic
Jan 16, 2007 12:40 PM
