1964 Olds Dynamic
HELP!!!! I cant find a fuel pump anywhere for this car.. Its been sitting in the tow yard for 2 weeks because they claim "they cant find the pump". Well, Ive been looking online for 2 hours now and havent found anything.. Does anyone have any suggestions?
usa parts has them for the 64 all v8 300 and 330 engines for $38.58. www.usapartssupply.com 1-800-872-2013. might also check with www.nosgm.com. im surprised that your local auto parts store cant get them. if those dont work you might pick up a hemmings catalog and go through the section covering oldsmobiles. im sure you could find something there. chris
It sounds like you need to get the car running in a hurry...I would buy a universal electric pump that you could mount to the frame near where the factory mechanical fuel pump is. With a power signal switched on by the ignition and a ground, you would be back in business. NAPA and other larger automotive stores sell pumps like this. Just be sure it does not supply too much pressure...I would guess a factory carb would not like more than 8-9psi (just my own guess).
Best of luck.
Best of luck.
Check out Fusicks and Kanter. They will probably also have what you want. Also, I have heard good things about the rebuild kits for mechanical fuel pumps. I have never used one of the rebuild kits, but a mechanical fuel pump is a simple device. I don't think it would be too difficult.
Fusick's lists the correct fuel pump for your '64 in their catalog. A few other places to call are:
Arizona Vintage Parts 800-433-977
GM Obsolete 602-253-8081
Terrill Mechine 254-893-2610
Best of luck.
Best of luck.
You need to be sure and get one that has been rebuilt with materials that tolerate modern fuels. Otherwise the diaphrams will disintegrate very quickly. Stay away from high-priced NOS units for the same reason.
MWS88Dynamic
Jan 16, 2007 12:40 PM
