1964 jetstar 88 sitting in a field.
Old Jan 29, 2015 | 07:54 AM
Nastardly's Avatar
The mention vehicle, a 64 j88 is mine, I inherited it in the mid of being worked on, supposedly it ran about a year ago, but I haven't been able to get to it to do much to it. Since about December of 2013 it's sat at a friend's house, undriven and virtually untouched. One thing I did do was open the gas tank and he good smell of acetone came out punched me in the face. Any suggestions on what I should do? My mechanic says to refill it with about 5 or more gallons of new gas, put some fuel stabilizer and it will be good to go. Does that sound like a bad idea to any of you guys?
Old Jan 29, 2015 | 08:29 AM
It depends on how long the fuel has been in there, and how much. When fuel sours and smells like varnish it starts to clot and cling to the inside of the tank and float assy. When you run that old fuel through the system its more like a gel and will basically clog the remaining fuel system. In the worst case it needs to be drained and cleaned out. I've found that a radiator shop is a good place to bring a tank to get the inside cleaned.
Old Jan 29, 2015 | 08:33 AM
Nastardly's Avatar
I think it's been a year or so. I'll probably just drop the fuel tank like you said. Thanks.
Old Jan 29, 2015 | 09:28 AM
Octania's Avatar
Nastardly-
welcome!
Tank is an easy fix, this happens all the time.
Keep an eye peeled in your area for the G400 engine from my car please.
VIN stamp on the block would be 38M______
I forget the last 6 numbers but if you find ANY G400 block stamped 38M.... I would be interested. Last seen in the Sacramento CA area c. 1985
Old Jan 29, 2015 | 05:58 PM
CreepyOldGuy's Avatar
At the very least I would drop the tank and have it professionally cleaned, checked and sealed if needed. Make sure you check all of your rubber fuel lines too. A carb rebuild probably would not hurt either. I'm going through the same thing on my 59'.
Mar 18, 2014 03:29 PM
scott_442
Sep 26, 2013 08:40 PM
Magna86
Feb 17, 2013 05:02 AM
2blu442
Feb 20, 2012 08:11 PM
74 Omega
Mar 8, 2010 06:30 AM
