1959 Super 88 four door hard top?
#41
Isn't the master cylinder on the 59 mounted on the firewall? I know it was on the Chevy. If so, there would me no treadle vac. It would just have a regular booster if it has power brakes. Twintracks you have more courage than I do. I shipped mine to Karps Power Brake Service in California and had it rebuilt. He did a great job and put a stainless sleeve in the cylinder. Not cheap but lots of piece of mind.
#42
I rebuilt the treadle-vac on my '55 98 myself with the kit from Fusick. It was no more difficult than rebuilding a carb. To me, stock is always simpler than modified. If you go that route, be sure to order the flexible brake hose that connects the treadle-vac to the hard lines.
#43
#45
What do you guys who have an operating treadle vac think of them? Should I get rid of it as part of my planned brake upgrades? I'm going disc in front and rebuild everything in back.
#46
I just like knowing how things work. Mine was clean as a whistle inside, so I ordered the kit. If I were to have found it to be rusty, I would have sent it to a professional. As it was, a few seals, and some new clamps, and she was good to go. I spent more time painting the case, than the time the rebuild took. Then, when I got it back in place the hose was leaking, so out it came again... I also replaced all of the wheel cylinders, and flex hoses. She locks them up now if I stand on it!
#47
If you are changing to front discs, you will need a dual chamber master cylinder. You'll be doing a lot of reengineering. I don't know if a dual chamber MC can be adapted to a treadle vac. I'm not trying to talk you out of it, I don't know what kind of driving you do, or what kind of traffic you will face. I do know that the stock components in working order will stop the car just fine, especially with radial tires. No need to argue the merits of brake upgrades. I understand that discs & a dual system is much safer. That's why I keep my emergency brake in working order, and practice using it.
Jerry
#48
If you are going to disk brakes, I think you will just about have to get away from the treadle vac. I would think on a 59 it would be fairly easy to adapt a swinging pedal and conventional booster and master cylinder. What you are at it you could use a dual master cylinder which give you added safety of a split system.
#49
My master cylinder, etc is just below the steering column as lazy says. I decided to convert to dot5 fluid and had rusty brake lines so I put in new lines and wheel cylinders. I removed the master cylinder / vac assembly and cleaned and rebuilt the MC. Only took the vac boost assembly apart enough to get at the MC. I did regrease the vac assembly with the special grease (can't remember what it's called) when I put everything back together. Seems to work fine, stops on a dime. IMHO, I'd leave it original and avoid the reengineering headaches. It's really a good system.
I would ABSOLUTELY buy and follow the manual in doing all disassembly and reassembly. And i suggest taking twice as many pictures as you think you'll need, then take more. Every picture at every angle has helped me and I wish I would have taken 300 more.
John
John
#53
#54
I ran into a title snag with the purchase of this car. Finally worked it out and will be picking it up this weekend.
I did make a road trip this weekend to grab the wheels off the car. I need to find some used tires before picking it up. The 40 year old dry rotted tires were a mess, no way I would get it on a trailer without tearing up the car and/or trailer. I was able to check out the car closer, finally able to look underneath. I am very happy with my purchase, the car looks great underneath, no rust, it's all there! Excited to get her home.
#56
#57
Good luck on your new purchase, you have just joined the ranks of the crazy Oldsmobile restorers and your life will never be the same. Road trips are now parts scrounging events and when the kids and wife start doing the who can spot the first Oldsmobile as you travel down the free way you will know that the whole family is now edicted to the Oldsmobile bug, a good but expensive disease.
Keep us posted on your on your travels through this build, the pictures you take now will forever be cherished, probably more so than the finished car, you can always take a new picture of a completed car , hard to review that old rusted hulk you started with after its all shinny and clean .
Sounds like you have done this before (not your first rodeo) but when finished I'll bet this car will be the one that stands out among all the rest, not many restore four doors and some day this will truly be rare and unique car.
Have fun with this build..... Lost in the fifties ...Tedd
#58
Yes, I have restored a few old cars in my time, but it has been awhile. My "project" cars over the last 15 yrs or so have been modern rice burner stuff. Can't wait to get my hands on some American steel!!!
I will take plenty of pics and document my build. I bought a .com today to document this build - rocketengineolds.com it is not up yet, sometime after the holiday's.
#59
Brought her home today
A couple of pics from picking her up below. I'm going to take a bunch of "before" pictures tomorrow and start cleaning her up. That is if the weather cooperates, snow in the forecast.
The more I look over the car, the more happy I am with it. I love the way it looks. Everything underneath look fantastic, no signs of rust on the frame very little of the body. Some of the trim needs help, but I knew this before purchase. The engine is free, oil and ATF look surprisingly clean for sitting for 40 yrs, no signs of any contamination. Excited to work on it! I will start a build thread and post more pics tomorrow.
Trailer pre-inspection by the local farm goat.
Installing tires/wheels and getting ready to load
Loading...
Ready for the ride home!
Loading...
1959 lowsmobile
February 8th, 2015 04:58 PM
cjprm
May 19th, 2011 09:17 AM
Wil Lopez
Ninety-Eight
August 29th, 2010 09:41 AM
64Super88
August 5th, 2010 03:40 AM
