68 442 axle bearing retainer plate
Old May 26, 2015 | 02:34 PM
muscle car resto's Avatar
Does anybody know what the torque specifications are for the four bolts that secure the axle bearing retainer plate.
Old May 26, 2015 | 04:35 PM
mrhotrod's Avatar
sure, factory specs are 40ft lbs for the axle bearing retainer/backing plate bolts.
Old May 26, 2015 | 04:45 PM
Octania's Avatar
3/8 is usually about 35 ft lbs. They are prevailing torque self locker fine thread, right?
I do not have the factory spec handy right now
mrexpedient beat me to it, superb
Old May 26, 2015 | 04:58 PM
mrhotrod's Avatar
lol seem to have this 69 Service manual open all the time for some reason. may as well someone got some use out of it hahaha..
Old May 26, 2015 | 07:06 PM
thanks oem specs is exactly what i wanted
Old May 26, 2015 | 07:44 PM
mrhotrod's Avatar
anytime, you should be fine as long as you are close with the stock type retainers. if you are using those heavy duty aluminum housed bearings then you probably need to use different numbers.
62 Olds
Mar 24, 2015 06:51 PM
BackInTheGame
Jun 8, 2013 07:50 AM
mbrae5
Sep 5, 2012 04:15 AM
Flye
Drivetrain/Differentials
Jul 30, 2009 10:24 AM
Bunser
Apr 21, 2008 03:12 AM
