12 Bolt Chevy value?
Old February 22nd, 2014, 10:53 AM
Registered car nut
nonhog's Avatar
I have a 1971 12 bolt w/ 3.31 non posi, no axles and unknown gear/bearing condition. Basically a core?
I have a few people interested and a loose offer of $300.00
Seems fair but I figured $500.00 based on some local CL ads.
Thing is I didn't follow those and find out what they actually sold for.
Be nice to take the 3 bills and be done. Unless its value is higher.
Too broke to rush into a low price(if it is?)
Thoughts?
nonhog is offline
Old February 22nd, 2014, 11:02 AM
oldsmobiledave's Avatar
Value
If the 3.31 gear set is useable then $500 is the price in my area. If it is just the housing then $350.
Good luck.
oldsmobiledave is offline
Old February 22nd, 2014, 12:06 PM
chadman's Avatar
A Chevy 12 bolt core is worth $450-$500 all day long. I would buy as many as you could bring me for $300 each.
chadman is offline
Old February 22nd, 2014, 08:49 PM
Registered car nut
nonhog's Avatar
Thanks guys!
nonhog is offline
Old February 22nd, 2014, 09:15 PM
66400's Avatar
Any idea as to value of a 65 Chevelle 12 bolt, 3:31 open?
66400 is offline
Old February 22nd, 2014, 09:52 PM
My experience
Typically the 65-67 12 bolt (1" narrower than the 68-72 version) will carry a $200-$350 premium.
Old February 23rd, 2014, 01:02 AM
nsnarsk65cutlass's Avatar
That maybe, but i think the value is greater that the 68-72 as there are less of them out there. Nick
nsnarsk65cutlass is offline
Old February 23rd, 2014, 06:54 AM
Octania's Avatar
violent agreement?
I understood "$200-$350 premium" to mean that amount over and above the price of the similar but different wider 68-72 more common units.
I know when a guy offered to sell me the 1968 O-type 3.08 12-bolt posi suitable for a '68 442 many years ago, for $125, I could not get there fast enough. I was running a 3.08 open at the time.
Later, when I went to install the 3.08 posi, I was refurbishing it for install when the 4.33 posi came along. I secretly bought it and installed that instead. Then let the wife test drive it.
"This thing won't shift out of 2nd gear"
"Try manually shifting it, I think you will get two shifts"
"screeeeeeech"
"What did you do to this thing? You put GEARS in it, didn't you?!"
Octania is offline
Old February 23rd, 2014, 07:04 AM
thanks
So what are you trying to say
Old February 23rd, 2014, 04:23 PM
You should pay less for 68-72.
Old February 24th, 2014, 07:25 PM
507OLDS's Avatar
All of the 12-bolt Chevy rears are sought after by the Chevelle guys,as well as others. The earlier 64-67 style is rarer than the 68-72,making them even more valuable.
The 3:31 ratio is also a sought after ratio. There are a few aftermarket companies making that ratio now,but the original GM's still bring at least $100.00 for a nice set.
The value of a 12-bolt Chevy housing will vary,depending on condition,if it is nice or pitted,and if there was ever anything done to it.
$300.00 for a good housing & good 3:31's inside,is on the cheap side. They should be throwing their money at you as soon as possible. I could care less about the factory axle shafts.They aren't that great,and are usually worn on the bearing surface,which is probably why they are missing.
507OLDS is offline
442Chris
Drivetrain/Differentials
December 7th, 2013 09:14 AM
Napoleon Solo
April 24th, 2013 11:02 AM
nonhog
December 11th, 2012 01:09 PM
VikingBlue
May 14th, 2011 07:28 PM
1BAD68"S"
December 29th, 2007 09:05 PM
Quick Reply: 12 Bolt Chevy value?
