best gears out there
I know this might be subject to debate,which is perfectly fine. Which ring and pinion gear manufacturer have you guys had the most success with? what about wheel bearing and U-joiunt?
71 cutlass supreme
455 425hp/500tq
2004r from bowtie OD/2200 stall
eaton tru trac complete unit/stock axles
71 cutlass supreme
455 425hp/500tq
Motyive gears and etc.
Well I have not seen a Motive gear that has had a MADE IN ITALY on the box in YEARS....
All I do know is Motive is really screwing up all the richmond boxed product there are gears in the wrong box and even ACTAL gears stamped WRONG
IE. 12 bolt 3.90 gears that motive sells are 4 series like GM. Well the Richmond gears are made to fit 3 series in the part number and all the sites. BUT the actual gear packed is a 4 series gear with the RICHMOND part number for the 3 series . YOU will go NUTS if you try to install the gear on a three series carrier.
IE. We received 3.42 Olds gears with 3.08 chevy truck gears in the box...etc.
IF they keep going like this they will go out of business. PERIOD. Richmond went out of business they same way Bad product and too many returns and letting equipment get old and out dated.
Good luck on your gear choice and NO MATTER what gear you purchase check everything as it may never be what it is suppose to be.
Jim
JD
Jim
JD
I know a few people that want to run those 12-bolt Chevy 4-series 3:90's on a spool.I know Greg Alexander actually ordered a custom spool made for his 3-series 3:90's.
You can get good patterns with the Richmond gears,IF you ignore the numbers scribed on them.
The last few I did, I put USA standard in. The runouts barely squeaked by, and one of the patterns was a little wobby sobby. they were not the best. BUT just fine for a derby car.
http://www.usastandardgear.com/Searc...earchPhrase=ZG
dave1978
Jan 9, 2021 07:13 AM
monzaz
Drivetrain/Differentials
Aug 7, 2014 11:12 AM
