1972 Cutlass 8.5 Rear end Help
Can anyone please help me out for upgrading my stock 2.56 non posi rearend. I wanted to know what would be the best gear ratio I was thinking 3.23 and a posi unit. Where would I get the parts that are good price and good quality? Thanks
I called some guys around here they want $1500+ to do the rearend. I looked on ebay and found this Eaton Posi Package GM 8.5 10 Bolt Gear Set Bearing 3.42 for $624. I am really good with my hands and wanted to do it myself but have never done it before. If someone could guide me I could probably get it. Thanks
I would put a 3:42 in it.There's a place in Iowa,Quick Performance that sells budget/cheaper kits for the 8.5" for $535.00 with free shipping.It's a copy of an Eaton posi,some type of gear,and japan bearings & seals.
If you are planning on trying it yourself,you will need a dial indicator at the least,and a spare pinion bearing,to hone-out,to trial-fit pinion shims.The pattern needs to be exact,or it will make noise & possibly eat itself.
That kit for $624.00 should have better pieces.Find out exactly what they are.
I want to know if theres anyone selling them in a package posi unit, gears, and the small parts. 3.42 may be too much for it and 3.23 is what I was told by my mechanic. I do want to do it be myself but never done it before and might have to get it done.
Those are packages.The one you found for $625.00,and the one I mentioned for $535.00,are kits or packages.They include the posi unit,gears,bearings & seals. I don't know if they include the installation shims or not.Check with them.
If you are looking for a complete rebuilt rear,ready to install,I have those for $975.00 plus the freight.
monzaz
Oct 26, 2020 07:05 PM
