1972 Cutlass 8.5 Rear end Help
Old May 25, 2011 | 05:01 PM
theoldsrocket's Avatar
http://www.youtube.com/wa
Can anyone please help me out for upgrading my stock 2.56 non posi rearend. I wanted to know what would be the best gear ratio I was thinking 3.23 and a posi unit. Where would I get the parts that are good price and good quality? Thanks
Old May 25, 2011 | 05:21 PM
oldzy's Avatar
2.32? I think you mean 3.23.
I say 3.23 or 3.42.
Old May 25, 2011 | 05:34 PM
ziff396's Avatar
I converted my 2.56 to a 3.42 posi. Seems just right for perfomance and driving the streets. If you run alot of highway, I would opt for the 3.23.
Old May 25, 2011 | 08:09 PM
507OLDS's Avatar
What are your intentions for your car? Engine size,tire size? Overdrive?
Old May 25, 2011 | 08:11 PM
I just want to cruise around in the car and drive it on weekends. It has a rebuilt olds 350 with a three speed tranny. I have 14 with 245 tires right now but might go to 15 with bigger tires.
Old May 25, 2011 | 08:19 PM
I called some guys around here they want $1500+ to do the rearend. I looked on ebay and found this Eaton Posi Package GM 8.5 10 Bolt Gear Set Bearing 3.42 for $624. I am really good with my hands and wanted to do it myself but have never done it before. If someone could guide me I could probably get it. Thanks
Old May 26, 2011 | 05:20 AM
507OLDS's Avatar
I would put a 3:42 in it.There's a place in Iowa,Quick Performance that sells budget/cheaper kits for the 8.5" for $535.00 with free shipping.It's a copy of an Eaton posi,some type of gear,and japan bearings & seals.
If you are planning on trying it yourself,you will need a dial indicator at the least,and a spare pinion bearing,to hone-out,to trial-fit pinion shims.The pattern needs to be exact,or it will make noise & possibly eat itself.
That kit for $624.00 should have better pieces.Find out exactly what they are.
Old May 26, 2011 | 08:01 PM
I want to know if theres anyone selling them in a package posi unit, gears, and the small parts. 3.42 may be too much for it and 3.23 is what I was told by my mechanic. I do want to do it be myself but never done it before and might have to get it done.
Old May 27, 2011 | 04:17 AM
507OLDS's Avatar
Those are packages.The one you found for $625.00,and the one I mentioned for $535.00,are kits or packages.They include the posi unit,gears,bearings & seals. I don't know if they include the installation shims or not.Check with them.
If you are looking for a complete rebuilt rear,ready to install,I have those for $975.00 plus the freight.
Old Feb 28, 2015 | 11:48 AM
juvieled's Avatar
How do i get in touch with you to get a order a 3.42 rear end ready to install
Old Feb 28, 2015 | 06:14 PM
oldsmobiledave's Avatar
think it through
Decide what tire you are going to run THEN pick your gear ratio. Keep the horse in front of the cart.
Old Mar 2, 2015 | 08:42 AM
monzaz's Avatar
paRTS
Stay away for the super cheap parts or you will end up with a headache and end up paying double down the road not to far...lol.
600-625 hear also is what I sell. Jim
monzaz
Oct 26, 2020 07:05 PM
kirksakar
Jul 9, 2015 05:15 PM
350TurBRO
Sep 12, 2014 11:52 AM
jpc647
Drivetrain/Differentials
Jul 7, 2014 10:39 PM
RuninWideOpen
Jan 17, 2014 04:48 PM
