Need part numbers
Old Jun 19, 2025 | 07:15 AM
LBost's Avatar
Need part numbers
Good morning
I think I have a source for the rear axle bearings, seals and retainers, but the supplier needs the part numbers
Does anyone one have part numbers for ‘69 Delta 88 Custom (with the 454 cdi engine)
- Rear axle bearing
- seals
-retainers
Thanks!!
Old Jun 19, 2025 | 09:18 AM
Tri-Carb's Avatar
If you call this Board member, he will have the parts to sell you and know correct the part numbers.
http://www.jdrace.com
Old Jun 21, 2025 | 03:53 AM
I assume this is the 9.3" Type O axle (12 bolt cover, 12 bolt ring gear).
Seal is P/N 406089. This crosses to Timken 8940S.
Bearing package is 907964 and includes the retainer as well as the bearing. This crosses to 88131R.
Old Jun 22, 2025 | 09:40 AM
monzaz's Avatar
88131R is a tough find if it is....
that part number is NOW a front wheel drive bearing...lol. REALLY they reused it ...unbelievable.
Another thing with FULL SIZE car axle bearings...GET THE actual OD and ID of the bearing as GM seem to have goofy info in MANY books and I have personally run into stff the books say it is suppose to be BUT of coarse are not...
Just to save you headaches.
I do not have ANY 88131R in stock....as I said this is a obsolete bearing...hard to get.
Jim JD race
Old Jun 22, 2025 | 02:25 PM
LBost's Avatar
Thank You
Thanks you for the insight - the chase goes on!
Old Jun 24, 2025 | 08:47 AM
LBost's Avatar
Jim, (your post on 6/22 on rear axle bearing numbers for '69 Olds)
Is 88131R just the bearing P/N, or a kit?
The parts manual lists a bearing P/N of 907964
Your help deciphering is sure appreciated.
Larry
Old Jun 24, 2025 | 09:45 AM
Tri-Carb's Avatar
Try https://mibearings.com/index.php?mai...t=6a&page=7346
Old Jun 24, 2025 | 10:37 AM
From post #3 above:
Old Jun 24, 2025 | 01:50 PM
monzaz's Avatar
Larry
likely a Timkin or National part number 88131R I do not know GM part numbers...Sorry.
Old Jun 24, 2025 | 02:00 PM
88131R is the Timken interchange number. This is from the 2011 printing of the Timken interchange book. Most other bearing vendors use this number as well (National, for example).
rr44270
Apr 12, 2018 09:19 AM
Railguy
Aug 21, 2016 05:38 PM
Sir_Charles
May 21, 2015 11:44 PM
Coosa31
Drivetrain/Differentials
Mar 15, 2015 07:20 AM
Roger
May 1, 2006 05:37 PM
