"O" axle berings and seals TO code
Old Apr 6, 2018 | 08:27 AM
rr44270's Avatar
I am having trouble sourcing the bearings and seals for my "TO" code rear end in my 70 W-31. Does anyone know any part numbers that will be easily located?
Old Apr 6, 2018 | 04:51 PM
techg8's Avatar
I recommend calling Jim Mitschke at JD race and Restoration, JDrace.com
He will have what you need or know where to get it. I think he might be on this board too, maybe member MONZAZ
Old Apr 6, 2018 | 06:36 PM
geardoc66's Avatar
Supercars Unlimited stocks those axle parts
http://www.supercarsunlimited.com/
Old Apr 7, 2018 | 10:10 AM
The '70 O-Type uses the same axle bearings and seals as the later corporate 8.5" 10 bolt (the earlier O-Type uses different bearings and seals).
The bearings and seals should be available from just about any auto parts store. Heck, even Amazon carries Timken bearings.
Below are the numbers I archived when I pulled my '70 O-Type apart:
Axle Bearing - Timken Set 9
Axle Seal - 712146
Carrier Bearing/Race - LM501314/LM501349
Pinion Bearing, front - M802048
Pinion Bearing, rear - M86649
Pinion Seal - 2043
Old Apr 9, 2018 | 05:43 AM
rr44270's Avatar
Thanks for the help. I will be doing it on a Saturday and I want to make sure I have all of the correct parts. The reason for my question is that my car is a vary early January build and I have heard that there were some 68-69 carryovers where they used different parts.
Old Apr 9, 2018 | 01:21 PM
They started building the 1970 model year cars in August of 1969, your car was built four + months into the production year, not an early build.
Old Apr 9, 2018 | 01:27 PM
rr44270's Avatar
Very true. I would assume that I have the part for the model year 1970 but wanted to be covered.
Old Apr 9, 2018 | 01:41 PM
You can confirm late vs early O-Type by the axle bearings and seals. The 67-69 uses a sealed bearing with an oil seal pressed into the end of the axle tube; the 70 uses an open bearing with the seal sandwiched between the axle bearing and the retaining flange.
Old Apr 9, 2018 | 01:57 PM
rr44270's Avatar
Thanks, I saw that. I just want to be prepared so I will check before I go to my buddy's shop. It is pretty obvious but I still have it in storage because our weather is terrible!
Old Apr 12, 2018 | 09:19 AM
rr44270's Avatar
Thanks for the info. He was great and I have ordered what we assume are the correct parts.
Oldssupreme
Drivetrain/Differentials
31
Apr 21, 2024 02:14 PM
war eagle
Sep 12, 2015 04:28 PM
Oldssupreme
Jul 31, 2014 07:58 PM
rrielley
Feb 9, 2008 10:43 AM
