Drive Shaft Length
Old March 6th, 2019, 01:06 PM
friesjh's Avatar
Drive Shaft Length
Hello all,
I am trying to find the drive shaft length for 71 442 4 speed car. I've looked through the Assembly and Service manuals with no luck. Where can I find the drive shaft length?
friesjh is offline
Old March 6th, 2019, 01:48 PM
alain's Avatar
The length is 56.5 inches .Available new rom the parts place
Alain
alain is offline
Old March 6th, 2019, 03:23 PM
442_1972's Avatar
Should be ~54 3/8” center to center on the u-joint holes. This assumes the correct 71 Muncie and 71 10 bolt rear axle are still in the car.
442_1972 is offline
Old March 6th, 2019, 05:35 PM
I'm betting this post Sorry my answer was for 1970 cars
Alain
...belongs on this page.
Vintage Chief is online now
Old March 6th, 2019, 05:50 PM
MOTORHEAD
11971four4two's Avatar
About 55 inches out side
you can fine tune the shaft with the yoke
Cut it down and bevel / polish that
11971four4two is online now
Old March 7th, 2019, 02:56 AM
alain's Avatar
Thanks Norm
Alain
alain is offline
Old March 7th, 2019, 05:33 AM
friesjh's Avatar
Guessing the 70 is different because of the different rear end than in 71??
The car does have the original rear end and transmission, so is the correct length 54 3/8" or 55"??
friesjh is offline
Old March 7th, 2019, 07:01 AM
442_1972's Avatar
The difference in driveshaft length for 71/72 cars is due to both the difference in the 70/71 rear axles and the difference in
length of the 71 and later Muncies (about 3/4” longer than 64-70 Muncies). I checked the driveshaft for my 72 4 speed 442 and it is ~54 3/8” c-to-c and the rear axle and Muncie are original 72 parts.
There are guides online about measuring for replacement driveshafts, so it may be a good idea to double check your car’s requirements in case you’re buying a replacement.
442_1972 is offline
oldsman72
Drivetrain/Differentials
June 17th, 2018 07:00 PM
Robert Kiedrowski
June 28th, 2015 05:22 AM
cwb442
December 31st, 2014 02:22 PM
70442
March 17th, 2013 10:05 AM
jensenracing77
May 13th, 2011 07:10 PM
Quick Reply: Drive Shaft Length
