O type aftermarket axles
Old January 4th, 2019, 03:08 AM
shiftbyear's Avatar
Are there aftermarket axles for a 1970 Cutlass "O" type rearend? Thanks
shiftbyear is offline
Old January 4th, 2019, 03:28 AM
Dockolds's Avatar
www.supercarsunlimited.com
Dockolds is offline
Old January 4th, 2019, 06:10 AM
Moser will make custom shafts to fit Type O axles.
joe_padavano is offline
Old January 4th, 2019, 09:39 AM
Gary
VC455's Avatar
I have Moser axle shafts in my Type O and they fit and function perfectly.
VC455 is online now
Old January 5th, 2019, 12:39 PM
monzaz's Avatar
Axles
We used Yukon gear and axle brand for aLL OUR REAR REBUILDS 1541h ALLOY we have not had any issues...
I sent a PM with prices?
Oh Also you should check to be sure you have 1970 axles ... the 67 68 69 (sealed bearings) are different than the 1970 which are oiled bearings .
We only use Moser if there is going to be some serious racing going on.
monzaz is offline
Old January 10th, 2019, 04:33 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I believe, with the aftermarket Type O posi, 71 and up axles can be used, is this correct?
olds 307 and 403 is offline
Old January 10th, 2019, 07:23 PM
No, the angle of the splines is different so the shaft will not insert into the differential side gears. Tried that back in the 80s and learned my lesson.
edit: I see that you said aftermarket posi. I do nont know about that, my experience was with a factory posi and factory axle shafts.
Fun71 is online now
Old January 11th, 2019, 07:05 AM
monzaz's Avatar
aftermarket posi
It is possible as FORD 8.8 units are used for this application and they are 28 spline and believed to be closet to the 45 degree same angle spline as the 71 72 axles. I will check for you. Jim
J D Race
monzaz is offline
Old January 12th, 2019, 05:57 AM
Do you have Chevy 12 bolt gears installed in your Type O? Just going by your signature. I know the Vista has bigger bearings, Brian Trick uses them for the ultimate Type O rear end builds. Monzaz, I am pretty sure Brian Trick said the 71-72 axle will fit with the 8.8 Ford posi.
Old January 12th, 2019, 03:22 PM
Gary
VC455's Avatar
Yes. Sent pm with some details.
VC455 is online now
August 6th, 2018 10:54 PM
servexcell
Drivetrain/Differentials
July 2nd, 2018 05:13 AM
70_442
June 6th, 2017 10:00 AM
442mark
March 18th, 2013 05:02 AM
olds1968
January 24th, 2008 07:35 AM
Quick Reply: O type aftermarket axles
