O type aftermarket axles
Old Jan 4, 2019 | 03:08 AM
shiftbyear's Avatar
Are there aftermarket axles for a 1970 Cutlass "O" type rearend? Thanks
Old Jan 4, 2019 | 03:28 AM
Dockolds's Avatar
www.supercarsunlimited.com
Old Jan 4, 2019 | 06:10 AM
Moser will make custom shafts to fit Type O axles.
Old Jan 4, 2019 | 09:39 AM
VC455's Avatar
Barely Registered
I have Moser axle shafts in my Type O and they fit and function perfectly.
Old Jan 5, 2019 | 12:39 PM
monzaz's Avatar
Axles
We used Yukon gear and axle brand for aLL OUR REAR REBUILDS 1541h ALLOY we have not had any issues...
I sent a PM with prices?
Oh Also you should check to be sure you have 1970 axles ... the 67 68 69 (sealed bearings) are different than the 1970 which are oiled bearings .
We only use Moser if there is going to be some serious racing going on.
Old Jan 10, 2019 | 04:33 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I believe, with the aftermarket Type O posi, 71 and up axles can be used, is this correct?
Old Jan 10, 2019 | 07:23 PM
No, the angle of the splines is different so the shaft will not insert into the differential side gears. Tried that back in the 80s and learned my lesson.
edit: I see that you said aftermarket posi. I do nont know about that, my experience was with a factory posi and factory axle shafts.
Old Jan 11, 2019 | 07:05 AM
monzaz's Avatar
aftermarket posi
It is possible as FORD 8.8 units are used for this application and they are 28 spline and believed to be closet to the 45 degree same angle spline as the 71 72 axles. I will check for you. Jim
J D Race
Old Jan 12, 2019 | 05:57 AM
Do you have Chevy 12 bolt gears installed in your Type O? Just going by your signature. I know the Vista has bigger bearings, Brian Trick uses them for the ultimate Type O rear end builds. Monzaz, I am pretty sure Brian Trick said the 71-72 axle will fit with the 8.8 Ford posi.
Old Jan 12, 2019 | 03:22 PM
VC455's Avatar
Barely Registered
Yes. Sent pm with some details.
Aug 6, 2018 10:54 PM
servexcell
Drivetrain/Differentials
Jul 2, 2018 05:13 AM
70_442
Jun 6, 2017 10:00 AM
442mark
Mar 18, 2013 05:02 AM
olds1968
Jan 24, 2008 07:35 AM
