What Type Rear Dif is This ?
Old Nov 15, 2019 | 03:18 PM
Cosmic Charlie's Avatar
This is in my 1969 Cutlass S ...
I cannot find any codes on the right axle, or the left for that mater.
I hoping not to have to remove the cover to find out.
If it is original it could be Type "O" ? (67-69).
It is an Open single track now
I'm just confirming what it is prior to replacing it with a posi unit - though not sure what route to go yet
Thx
Old Nov 15, 2019 | 03:34 PM
Yes it's a Type O.
Old Nov 15, 2019 | 03:42 PM
Thank You
Old Nov 15, 2019 | 10:03 PM
Yellowstatue's Avatar
Look on the front of the tube, close to the tail pipe.
Old Nov 16, 2019 | 06:18 AM
This is my Right Axle facing front toward the top - I see nothing - and I have checked like 3 times after cleaning it up +- There is a vent hole on top (without the rubber plug sealing the hole +-)
Old Nov 16, 2019 | 07:17 AM
Yeah, I see that. Sometimes the stamp is so faint that it is invisible. Try wetting it with WD40.
Old Nov 16, 2019 | 09:07 PM
monzaz's Avatar
ALL ARE ON THE PASSENGER TUBE FACING THE REAR OF THE CAR AND THE LETTERS ARE USUALLY UPSIDE DOWN
2 LETTER/ NUMBER CODE
Geez, Not yelling with the caps. . sorry.
IE - R2 SA SC something like that
\Looks like it might be a bit tight where you need to look behind that passenger exhaust tube.
wire wheel / flat file / if it is too rusty it may be a moot point.
Rvsmith5
Drivetrain/Differentials
Dec 1, 2018 06:48 AM
foo
24
Aug 9, 2012 05:43 AM
Magna86
Apr 24, 2012 04:51 AM
allyolds68
May 21, 2011 09:31 PM
my67olds
May 14, 2008 03:46 PM
