Wagon axle
Old Jun 25, 2020 | 01:28 PM
11971four4two's Avatar
MOTORHEAD
Wagon axle
Date on the gear set 1972 O Center section
Crazy backing plates and wide shoe
I can find no code stamps on the tubes
It has GM gears
Leave it??
Or change backing plates and make a regular cutlass
Then what to do with the BIG brakes??
Old Jun 25, 2020 | 01:37 PM
MOTORHEAD
pictures
Old Jun 25, 2020 | 03:35 PM
What's wrong with bigger brakes?
Old Jun 26, 2020 | 07:15 AM
monzaz's Avatar
Only down to the bigger brakes is finding and buying the brakes... I have not looked up the parts to see how difficult they would be to get.
Shoes ? should be out there hardware definitely easy left right adjust kits same as 9.5 x 2
wheel cylinder is different for sure.
Drums might be a pain? Wagon only. If the drums look like they have life... blast and have them machined, reuse.
Jim
JD
Old Jun 26, 2020 | 07:16 AM
Jim
JD
The Vista rear brakes use the same 9.5 x 2.5 shoes as the front brakes on A-body cars. The parts grow on trees. The front drums also interchange with the rears.
Old Jun 26, 2020 | 09:31 AM
JohnnyBs68S's Avatar
I agree that the bigger brakes are a plus, and REPAIR parts are available. But those backing plates are unique to the Vista rears, are they not? IIRC, sourcing those was the roadblock to me swapping to Vista brakes when I rebuilt my rear end. DO NOT SCRAP those.
Old Jun 26, 2020 | 10:48 AM
He's already got the backing plates. Yes they are unique to the Vista and SportWagon
Old Jun 26, 2020 | 11:02 AM
monzaz's Avatar
There you go...All the info you need.
Do not do front ends...lol
Old Jun 26, 2020 | 03:30 PM
MOTORHEAD
Thanks for the replies
The brakes were really rusted on. The drums have chunks "shrapnel" missing from the edge from hammer and pry bars.
It is nice to know there are parts available for the big brakes today. I am going to mothball the axle for now and try and find a posi unit or two and some gears
Cheers
brian
Old Jun 27, 2020 | 06:26 AM
Magna86's Avatar
The bigger rear brakes is a nice upgrade without the hassle of going through a disc conversion or worrying about wheels fitting. I had them on my 71 and the distribution block didn't need changed either. I will tell you the rear cylinders are like 3 times the cost of a regular A body one. Atleast that's what I found for an O type Vista Rear. Gears and posi should be cheaper and easier to find than an O type too.
Mirko 73
Oct 16, 2024 12:24 PM
mineseats9
Oct 8, 2019 08:57 AM
gearheads78
Jun 3, 2019 11:08 AM
flfinecars
Jan 9, 2014 10:43 AM
flfinecars
Jan 9, 2014 06:32 AM
