Swap engine - tire size = what gear?
Old Oct 14, 2018 | 07:05 PM
Via3d's Avatar
If I swap an Olds engine from a late 60's early 70's car with stock 14" wheels, 300hp+ motor & 3.08 stocking gearing... and I am putting it into a late 70's car with stock 15" wheels & 2.73 gear - should I account for the tire size difference to match the original gearing of the motor?
In other words, switch to a 3.23 gear with 15" wheels that is equivalent to a 3.08 gear with 14" tires.
Old Oct 15, 2018 | 05:38 AM
Wheel size is irrelevant to rear end gearing, tire diameter is what gearing is based on.
Old Oct 15, 2018 | 07:25 AM
Via3d's Avatar
Apologies your correct. the 14" stock was 26.4"
My TA tires are stock size... BFG's are 27.4" so 1" difference.
Old Oct 15, 2018 | 08:14 AM
Math is your friend...
Simply ratio the diameters. 27.4/26.4 = 1.04 (ie, a 4% difference). 1.04 x 3.08 = 3.20 gearing for the same effective ratio at the tires. 3.23 is the closest available ratio.
Old Oct 15, 2018 | 09:15 AM
Via3d's Avatar
I like the term you used Joe "effective ratio".
That is what my main question is, should I aim to achieve the same effective ratio going to a 3.23 ? (that was setup with the motor originally with 3.08 gear and 26.4" tires)
Assumption being this was the performance setup from the Olds engineers that may be the the best overall street cruiser/highway setup ???
CutLS442
Drivetrain/Differentials
Nov 23, 2016 12:56 PM
2oldsguy
Wheels and Tires
Apr 9, 2015 04:46 AM
442b
Jul 16, 2014 07:37 PM
FIJIBLUE72
Wheels and Tires
Sep 28, 2010 05:08 PM
ELECMAN
Dec 28, 2009 08:56 PM
