Oldsmobile Cutlass Supreme -69. 350 sbo originally with 2 barrel carb. What is my stock rear end ratio?
I'm planning a 4-speed conversion with overdrive and at the same time shorter ratio for rear end. Th2004r would be the easiest choice for a transmission. I still would like the overdrive to be "longer" than my 3rd now is. Need to find suitable rear end ratio.
The base equipment rear axle ratio was 2.56:1 with the TH350. Of course, seven other ratios were optionally available. Unless you know for a fact that the car has the base ratio, you can't tell without finding the code or counting teeth.
Easier yet would be to find the two letter code stamped into right side axle tube.
The 200-4R won't like 2.56 gears due to the steep overdrive (.67). For example, .67*2.56 = 1 tire rev per 1.7 engine revs. At highway speeds, the engine is practically idling. The best idea is to change differential gear ratio to match the original 2.56 for highway cruising => 2.56/.67 = 3.82. The nearest aftermarket gear set is 3.90 for the "O" axle. This will enable tire frying launch torque but when on the highway, it's just like running 2.56 again!
