Please help identify this axel
Old May 25, 2016 | 10:52 PM
Nickyloves442s's Avatar
480632 casting number. 3:23 gears. Will it fit an a body. Is it similar or the same as a corporate 10 bolt.
Old May 26, 2016 | 05:28 AM
svnt442's Avatar
Everything that I could find says that is a big car axle. So it would be too wide and have the incorrect mounting locations for an A body.
Old May 26, 2016 | 10:27 AM
monzaz's Avatar
Not a body
If it is a A body it will be from the 1973-1977 era.... WILL NOT FIT the 65-72 era at all. Period. Jim
It is a 8.75 rear-
it will have 12 bolt ring gear
28 or 31 spline axles
NO PART ARE AVAILABLE for this in the aftermarket
I have a posi for that rear if you need
28 spline axle unit
Mostly found in the 78-85 GM wagons and caddy devilles.
Old May 26, 2016 | 01:31 PM
Thank you guys so much. It was on craigslist and I was thinking about picking it up. Wanted to know of the case or guys would fit in my a bodies. Its a posi, but apparently no use to me.
Old May 28, 2016 | 08:49 PM
monzaz's Avatar
stay away
Yep... Pull the hook and swim away. Jim
AK71CutlassS
May 28, 2014 07:16 AM
JJSCUTLASS
Oct 23, 2012 04:05 PM
lowkey235
Aug 17, 2012 10:59 PM
Rick E
May 12, 2012 07:12 PM
oldsrocket88
Mar 1, 2012 11:38 AM
