Need help with noises from rear end
Old May 16, 2014 | 09:23 PM
H8D-67's Avatar
So recently I have been getting what I can best describe as a creaking noise from the drivers rear of my 67. I believed it to be my rear drums as they were shot. I put all new shoes, drums, hardware and wheel cylinders on the back along with some new 275/60/15 tires and I am still hearing the creaking. While I had the drivers rear drum off I noticed the axle has about 1/4 inch of play pushing and pulling it out and some up and down. So the bearing is most likely shot. Would a bearing make this creaking noise? Also it only happens under load, if I lift it on a rack and put it in drive or just spin the wheels there is no sound. Seems to happen under 40mph but that could mean I just don't hear it after that. Any help would be awesome.
Old May 17, 2014 | 09:31 AM
jaunty75's Avatar
It's probably the bearing as you suspect. The noise going away above 40 mph doesn't say much as the road noise and the frequency of the creaking both get too high to hear the sound.
When you hear the sound, step on the brake. If the sound disappears or changes in any way, the bearing is suspect as you are changing the load on it.
Old May 17, 2014 | 09:40 AM
krazee442man's Avatar
My answer is the same as jauntys' . I had a 68 442 that did the same thing. Right rear wheel bearing was shot.
Old May 17, 2014 | 09:56 AM
H8D-67's Avatar
I figured it had to be the bearing. I just thought it would squeal or be a little more high pitched not this weird creaking noise. Worried that bearing has possibly grooved the axle though. Dont want to put too much money into this 12 bolt considering Ill be changing it out anyways.
Old May 17, 2014 | 11:25 AM
jaunty75's Avatar
I had this problem with a '64 Jetstar 88 I once owned, and by the time I diagnosed the problem and checked the bearing, the axle on that side had already been damaged. I was fortunate to find another '64 J-88 in a nearby junkyard and took the axle off of that one. This was almost 25 years ago now.
Old May 17, 2014 | 12:38 PM
Bearings usually emit a rumbling type noise. Not usually a creak or a squeal, but hey anything is possible. They don't usually eat the axle as there is an inner and outer race. It could also be a ujoint.
Old May 17, 2014 | 07:14 PM
H8D-67's Avatar
You actually may be right, just looked for some videos online of what a bad ujoint sounds like and found this
Sounds almost identical to what I'm hearing. Like a door that creeks when you open it.
Old Mar 12, 2015 | 04:21 AM
oldsconv's Avatar
I had a similar creaking sound like a door hinge on my 64 F85 years ago. Not really a high pitched squeal, mre creaking. The bearing had seized up and the inner race (pressed on type bearing) broke loose and the race was basically riding dry on the axle. Ruined the axle needless to say.
Old Mar 12, 2015 | 04:55 AM
gs72's Avatar
72Cutlass S
Inspect the u-joints closely, you are probably going to see a fine red powder around one or more of thr u-joint seals. This is evidence that the needle bearings are dry/rusted and grinding themselves up.
Old Mar 12, 2015 | 09:04 AM
Octania's Avatar
new U-Joints is easy and always beneficial anyhow.
I'd pull the axles and at least inspect the bearings.
Old Mar 12, 2015 | 10:09 AM
pmathews's Avatar
When my rear axle bearing failed, it made the same creaky noise at lower speeds that you are describing. On the highway, I couldn't hear anything, but then again, those Flowmasters probably had something to do with that.
Take a quick look at my thread on the topic, the bearings are easy to check.
https://classicoldsmobile.com/forums...see-video.html
Old Mar 12, 2015 | 10:28 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
If its NOT a bad u-joint pull the axles and inspect the outer bearings. If you let axle bearings go too long it will damage the axle. X2 what oldcutlass and all say...Either way purchase USA high quality parts for either. Spicer for the u-joint. For rear axle bearings contact BDI Inc. for guidance as they can be hard to find. Ask for USA not offshore. For some reason they offer up the offshore first. Sometimes the USA bearings are actually cheaper.
Old Mar 12, 2015 | 11:05 AM
boese1978's Avatar
Perhaps you are hearing a squeak from a body mount bushing or control arm bushing.....
Old Mar 13, 2015 | 06:37 AM
monzaz's Avatar
Check your brakes
Check the brakes as they shift and in forward they will shift to the usually driving forward wear pattern.
That is my best guess parking brake etc. Good luck. Jim
OR
Check to see if something is rubbing on a wheel or drive shaft if it lays on the shaft it will not make noise...but in reverse it will hit a sharp edge from going in reverse causing that squeak noise. Jim
That's all I got.
Old Mar 13, 2015 | 10:09 AM
You guys know you're addressing a thread that's almost a year old?
Old Mar 13, 2015 | 10:43 AM
Gas-X.
Old Mar 13, 2015 | 02:09 PM
^^^^ LMAO good one!^^^
Old Mar 15, 2015 | 07:39 PM
monzaz's Avatar
Oh Well
Well you never know if someone Google's noise issues it still might help...LOL.
GAS - X is a good one
slade69
Suspension & Handling
Sep 16, 2013 07:09 AM
MaxDog
Apr 3, 2013 10:48 AM
jkoester122
Aug 30, 2011 05:04 PM
cluelesscutlass
Aug 13, 2011 06:55 AM
WasteOfMind00
Apr 18, 2007 08:10 AM
