how do i decode my rear end??!!
Old Nov 12, 2007 | 06:10 PM
gabes455olds's Avatar
Red face how do i decode my rear end??!!
Hi everyone,
hopefully someone can help me decode my diff. I have a 72 cutlass and I have some numbers and letters that i got from the diff. Can anyone tell me how to decode them?
J-159
1385724-F
123487890 (on driver side)
Old Nov 15, 2007 | 09:38 PM
monzaz's Avatar
decoding
You need the axle tube suffix to tell you what is in the rear diff and where it was built and the date it was built. It is usually found on the passenger axle tube facing the front of the car parallel with the ground it will have a couple of letters or a letter and a number then a space then some more numbers and maybe another letter. use a wire wheel or sand paper etc. Take a look and get us those letters and numbers and will figure it out for you. Jim
Old Nov 15, 2007 | 09:51 PM
monzaz's Avatar
number you gave
The 1234567890 are test number (example stampings to compare to) they mean nothing.
1385724-F Is most likely the casting number which will tell you it is a 10 bolt 8.5 cutlas rear if it is original. I am not that great with the casting numbers. If you have a picture I know the gm rears by physical casting identification (sight)
J-159
this could be a date code of when the housing was cast J = 10th month Oct. 15 th day and 9 is 1969 ...But that usually is chevy stuff.
Jim
Old May 30, 2008 | 07:43 PM
apachemobile's Avatar
I don't want to hijack the thread, but I need help with this also. I have a 1958 Chevy Apache sitting on what I am told is a Delta 88. I am unsure of this due to the fact that engine was a SBO 350 1973-1974. Is there anyway I can ID the model and year of this car.
I looked on the rear end and I made out ACO 311.
Any help would be much appreciated. Thanks
Old May 30, 2008 | 08:59 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
HELL YEAH!!!!
I have a 60 Apache.
It will be getting restored next summer!
350TurBRO
Sep 12, 2014 11:52 AM
MDchanic
31
Aug 12, 2012 04:24 AM
stlbluesbrother
Drivetrain/Differentials
Feb 21, 2012 08:13 AM
CutlassLegend
Aug 17, 2011 12:10 PM
Jamesbo
Jan 15, 2010 11:52 AM
