how do i check the rearend gear ratio
i read in a post here mention of checking the ratio by jacking the car up and turning the rear tire while counting the revolutions of the driveshaft. can anybody give me instructions on how to go about this and how to interpret my results? im assuming my 72 delta has the stock rear end (not even sure what the stock ratio is) due to the 2bbl carb on it.... seems that would be the first step in performance upgrades. a simple test like watching the driveline spin will tell me for sure.
what should the stock ratio be? its a 72 delta 350 2bbl with a th375
thanks in advance for the help
thanks. i was hoping the cheaters way to check would save me some time and money lol but ya i see your point. its not a posi and no i havent checked for a code... wasnt aware there was one. can you give an example of what im looking for? ie: six digit number, letter code, 9Mxxx
thank you
thank you
Here's something that might help you find the stampings
Joe P's "Cheater method"
Jack up the rear of the car. Make a chalk mark on one tire and on the driveshaft. Turn the tire ten times while counting the number of driveshaft revolutions. Divide the driveshaft revs by ten. That's the ratio. You can also do this by rotating the tire once, but the difference between 3.31 and 3.42 (as an example) is impossible to discern. On the other hand, the difference between 33.1 and 34.2 is easy to see. That's why I use ten turns of the tire.
Isn't cut and paste wonderful.
thanks everybody! everyone here is so helpful. this is my first oldsmobile, well my first car project really, and im excited about doing a lot of it myself. i dont know what i would do without having a resource like your olds forum to glean information, ideas, and instructions from!
thanks again to everyone here that helps out those of us who would be lost otherwise
