How can this be?
Old Jun 23, 2025 | 04:56 PM
72455's Avatar
1972 U code Supreme
How can this be?
As I've previously noted in another thread, I was dealing with a pinion seal leak on my '72 Supreme. I had it replaced back in September of last year, and while it helped, I still have a leak. Since it is a static leak, I keep a close eye on it and check the level about once a month.
It's been about 2,000 miles since I had the seal replaced, and I have not added fluid since. Yet, when I check it, my level is still good.
If I've had a leak all this time, how can it be that I still haven't needed to add fluid? 🤔
Old Jun 23, 2025 | 05:25 PM
OLDSter Ralph's Avatar
I can think of several things. Oil/fluid can spread out a lot.
Another things is the volume of most fluids expand with a temperature increase. If you put in oil that was 72 degrees and its now 95 degrees, its still full.
Old Jun 23, 2025 | 05:38 PM
Dave - Depends on how you're quantifying a "leak". There are ~20 "drops" in a typical eye dropper. A typical eye dropper contains ~20 mL (milliliters). Therefore, there are 20ml/eye dropper. There are 1,000 mL/liter. One mL = 1 cubic cm. 16oz/pint or 568mL/pint. There are 0.033811 ounces/mL.
An Open Differential will typically hold ~4.25 pints diffy fluid. A posi will typically hold ~5.4 pints diffy fluid.
Do you have a "leak" or are you losing a couple "drops" (milliliters) of fluid? You'd have to lose an appreciable amount of fluid to have a "leak". If you haven't had to add fluid, I doubt you have a "leak" (per se).
Old Jun 23, 2025 | 05:41 PM
As noted, differential fluid expands when heated. Perhaps what you're experiencing is a little seepage (from expansion) rather than a leak (per se)?
Old Jun 23, 2025 | 07:07 PM
72455's Avatar
1972 U code Supreme
I guess that makes sense, but I would think I would of had to add fluid at some point along the way.
Old Jun 23, 2025 | 07:10 PM
72455's Avatar
1972 U code Supreme
A seepage for 9 months in varying temperatures? Seems to me the "heat expansion" theory wouldn't apply when it's cooler outside, especially during winter.
Old Jun 23, 2025 | 07:25 PM
Well, unless you can quantify a leak you haven’t convinced me you have ANY leak if you have NOT had to add fluid. Who’s kidding who here?
Old Jun 23, 2025 | 07:31 PM
72455's Avatar
1972 U code Supreme
Ok Norm, so it's more like a drip, but still, even a drip would create the need to add fluid at some point after 9 months, correct?
Old Jun 23, 2025 | 07:40 PM
If you don’t have to add fluid, you have no “leak”.
Old Jun 23, 2025 | 07:48 PM
72455's Avatar
1972 U code Supreme
The fluid is coming from somewhere because I have a drip that forms on the housing right under the seal.
Old Jun 23, 2025 | 08:56 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
If the seal surface on the pinion was grooved a new seal will not prevent leaks.
Several tricks to remedy this:
-Installing the seal slight deeper or shallower to grab a good surface.
-You may have damaged the new seal during installation. Did you pack the back side of the seal with Vaseline to prevent the spring from dislodging?
-A speedy sleeve may be needed. Beware...the sleeve can follow the groove if its deep enough and you dont fill it with JB. This is an art Ive perfected. If you need more info ask.
Old Jun 26, 2025 | 02:18 PM
72455's Avatar
1972 U code Supreme
So this is what I'm using to catch the diff fluid drips. I cleaned it up 6 hours ago and here's what I have now. Does this quantify as a leak?
Old Jun 26, 2025 | 02:53 PM
Dave - What is it we're looking at in the image? What is the exact size of that red apparent rubber "thing". Why do I see what appears to be oil underneath/below the Duralast script? Is that Duralast script floating above the apparent oil? I'm (easily) confused.
Old Jun 26, 2025 | 05:58 PM
72455's Avatar
1972 U code Supreme
Norm-it measures approximately 4"x 4" and maybe 3/8" deep. The white spot you see on the Duralast logo is residue from the brake cleaner I used to clean it up today. That is at the bottom. The diff fluid is on top of the logo.
Old Jun 26, 2025 | 09:06 PM
To answer your question - is it a leak? I think you'd be better served to "measure" the volume (amount) of fluid e.g. in a small fluid oz. container.
Old Jun 27, 2025 | 03:34 AM
72455's Avatar
1972 U code Supreme
That's exactly what I was thinking...great minds think alike...
Old Jun 27, 2025 | 08:22 AM
oddball's Avatar
It's a leak, sure, but it's so slow and small that you may just be chasing your own tail. I had a very slow pinion leak that I just never could fix. Tried several seals, never got better. Just had to live with it - until I replaced the entire rear end.
A very small amount of oil makes a very large mess. It's funny because a BIG leak will often just flow away and make a mess on the floor, but may not "look" as bad as a very slow leak that dumps just enough oil to spread out and catch dirt.
Old Jun 27, 2025 | 08:48 AM
72455's Avatar
1972 U code Supreme
I'm ok with letting it be, but I don't get why I haven't had to add fluid since September of last year. 🤔
Old Jul 12, 2025 | 05:51 PM
72455's Avatar
1972 U code Supreme
So since June 30th, I've accumulated a little less than an ounce. Unless my math is off, this equates to a total leak loss of 20 ounces (give or take) since September 15th. Yet, as I have said, the level in the housing is still good. 🤔
Old Jul 12, 2025 | 06:38 PM
Exactly what is the figure supposed to represent? I see the "1/2" (of something) w/ markings of 2, 4 & 6 (of something). I'm more confused now than I was previously.
Old Jul 12, 2025 | 07:23 PM
OK. I had to figure it out myself. Eight (8) ounces to one (1) cup. The "1/2" = 1/2 cup. Still, the bottom line appears to suggest a little less than 1 & 1/2 ounces. The image is not convincing.
Old Jul 12, 2025 | 07:35 PM
72455's Avatar
1972 U code Supreme
Norm, each graduation line is one ounce, and I'm not understanding what's not convincing to you. It seems pretty clear to me...as stated above, in two weeks I've accumulated just under 1 ounce of diff fluid.
Old Jul 12, 2025 | 07:49 PM
My mistake, I did say a little less than 1 & 1/2 ounces it does demonstrate a little less than 1 ounce.
Old Jul 12, 2025 | 08:07 PM
Sixteen (16) fluid oz./one liquid pint. A typical (not posi) differential holds ~4.25 pints (posi ~5.4); therefore, a typical non-posi holds ~68 fl. oz. Albeit, 1 oz/68 oz means you've captured <1.5% of the total fluid volume.
Old Jul 13, 2025 | 07:48 AM
JohnnyBs68S's Avatar
Maybe in 9 years. Unless it is leaving a large puddle under your rear that needs to be wiped up weekly, you'll barely notice a measurable decrease in fluid level by sticking your finger in a hole. Even if the level drops an inch (which would be ALOT of fluid), your rear will still be adequately lubed since the ring gear acts as a pump to splash the fluid up towards a channel in the top of the housing that allows fluid to flow down the the pinion bearing. Rear end fluid level needs to be sufficient, but it is not critical.
Old Jul 13, 2025 | 11:42 AM
72455's Avatar
1972 U code Supreme
Huh..ok. I was just curious about it, that's all.
Old Aug 3, 2025 | 12:42 PM
72455's Avatar
1972 U code Supreme
The saga continues...
Ok, so here's the latest data. I took it to a car show a week ago yesterday, and it was pretty steamy out. (95 deg with a heat index of ~105.) Up until then, the level had been holding pretty steady for the past month at ~1 oz. When I checked it this past Thursday, it had increased to 2 oz. (That’s an increase of 1 oz in just 4 days).
I checked the level, and it was still good (1/2 way up my pinky nail). Having said that, I was concerned that the issue had gotten worse, but decided to keep an eye on it.
So for the past 4 days, I've checked it every day, and it's still right at 2 oz.
My question is, why would it increase another ounce in just 4 days when up until then (and since), it's held steady @ ~1 oz? Is it because it was hot the day I took it to the car show and it was due to expansion (as Norm eluded to in #4 above?) I will also note that I've driven it on other days just as hot this summer, and I've noticed no level increase.
Old Aug 3, 2025 | 01:57 PM
Man, you need a hobby.
Oh ... wait.
Old Aug 3, 2025 | 02:19 PM
OK, Dave - let's test my memory. Wasn't there a time (last year?) when you found you had no vent tube in your rear axle & you elected to install an axle vent tube (AKA differential vent)? Without a complete revisit of that dialogue a differential/axle vent is critically important. Motoring about at ANY speed causes heat to build in the differential & internal to the axles. When heat builds pressure builds - the purpose of that vent is to vent pressure resulting from the increased heat when motoring about. "If" that vent is clogged, won't open or otherwise the incorrect vent installed - you got it. Pressure will build & continue to build in the differential & the axles. You might have a gander at your differential/axle vent.
Yes, it will cause seals to leak.
Old Aug 3, 2025 | 02:21 PM
72455's Avatar
1972 U code Supreme
Originally Posted by bangscreech4-4-2
man, you need a hobby.
Oh ... Wait.
Old Aug 3, 2025 | 02:22 PM
  #31
72455's Avatar
1972 U code Supreme
Norm, I replaced the vent tube with a brand new one last year.
Old Aug 3, 2025 | 02:23 PM
  #32
Is it the correct one? Was installed correctly? Is it "working" properly?
Old Aug 3, 2025 | 02:39 PM
  #33
Remove the vent/differential vent you installed. Use something you won't drop into the axle vent hole (long paper clip?, pointed drift/punch, etc.? - ensure the hole is not clogged, plugged, etc.). Then, ride about for several weeks (or longer) w/ no vent - just leave the hole open. See if your drip stops.
Old Aug 3, 2025 | 02:46 PM
  #34
72455's Avatar
1972 U code Supreme
Yes, yes and yes (I literally just walked out and checked it.)
Old Aug 4, 2025 | 02:43 PM
  #35
Is the vent open to breath?
Old Aug 4, 2025 | 02:52 PM
  #36
When I did Drag week back in 2016, I noticed on the first day I had a leak from the C clip eliminators on my car. There was gear oil spray pattern all over the tire. Since parts and a press to change it wasn’t something I packed, I put it out of my mind. I drove the entire event, plus the drive home. All told probably 2000 miles. I have no clue how long it had been leaking before, what I do know that the rearend had plenty of oil when I fixed it later.
The differential on my 06 Ram is always a little damp, but it never leaves a puddle in the driveway. I frequently check the diffs and transfer case fluid levels, I never need to add any.
My point: a tiny amount of fluid can spread out over a very large area when it’s being blown around by the wind under the car.
If you don’t have to add fluid, it’s not leaking enough to worry about.
Old Aug 4, 2025 | 03:26 PM
  #37
I have differential leaks on two cars (at least) and have never had to add any. Considering that capacity is something like 50 ounces and you measure with a finger, that's about 4%. You can't tell.
This is a check it once a year thing and be happy.
Old Aug 5, 2025 | 05:14 AM
  #38
CutlassMarc's Avatar
Does the factory posi rears have a bigger/deeper cover than a open.
Try'n to wrap my head around how a posi holds 1.15 pints more fluid than the open. The open has a lot less parts in the center of it than the posi that has plates/clutches and springs. I'd think all that extra metal parts would take up more space limiting the fluid , not allowing more.
Old Aug 5, 2025 | 06:46 AM
  #39
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yeah, this reminds of replacing seals on a TH350 or TH2004R, only slightly slow down the leaks. Try 85W140 and call it good. Or a new yoke or sleeve and seal. The only leak I had was the cover on my 8.5" Type O, tightened and all was good. Your leak is what my 4L80E leaks which I call as good as no leak on old automatics.
AK Cutlass
Feb 23, 2025 01:40 PM
72455
Drivetrain/Differentials
46
Sep 1, 2023 07:59 AM
hwalzer
Aug 23, 2021 02:56 PM
82cutlass
Dec 7, 2015 09:47 AM
Gary's 2 442-S
Sep 24, 2012 10:56 AM
