High speed driveline vibration
Old Apr 12, 2018 | 10:20 PM
JRSL69's Avatar
J.R.
Any ideas on why I am getting a high speed drive line vibration when I let off the throttle at speeds over 70mph on my 66 442. U-joints are good and properly installed. I tried changing the orientation of the driveshaft with the rear end with no change. There is no vibration when accelerating or cruising, just when I let off at higher speeds and no difference if I push the clutch in or shift to neutral. Thanks Jim.
Old Apr 13, 2018 | 05:42 PM
1970greensupreme's Avatar
driveline angle change on decel. Could have a bad trans mount, rear control arm bushing for your rear. I would start looking at this since you don't have it on accel or steady state.
Old Apr 13, 2018 | 05:48 PM
Oldcoyote's Avatar
On my G body I had vibration .I took it to a driveline shop and they rebalanced the driveshaft. Fixed .
Old Apr 13, 2018 | 07:35 PM
classicmuscle442's Avatar
Had a vibration in my '65, found the driveshaft to be too straight. Added couple washers under trans mount bolts to add a bit of an angle.
Old Apr 14, 2018 | 10:26 AM
JRSL69's Avatar
J.R.
Thanks guys, sounds like I need to take a good look at the condition of my rear end bushings and trans mount.
papsmac
Mar 2, 2016 05:19 PM
jtdb153
Drivetrain/Differentials
Jun 9, 2015 04:14 AM
STLCRZY
May 4, 2014 12:49 PM
Demonator666
Wheels and Tires
May 29, 2012 10:28 PM
club442
Jul 10, 2009 05:25 PM
