Click Here
High Speed Vibration, '72 H/O
Old March 12th, 2012, 05:03 PM
Demonator666's Avatar
just like 455Man, I also have a high speed vibration. It starts at 58MPH, shaking the intire car. The flapper door on the 8-track rattles like crazy. The car has new rotors and drums, new tires (ballanced twice), new u-joints and ballanced driveshaft. The only thing different from factory specs is I went from 14" SSIII to 15" SSIII. Any thoughts?
Demonator666 is offline
Old March 12th, 2012, 06:41 PM
Lady72nRob71's Avatar
Would these wheels have snap on or bolt on caps? The wheels with snap ons need to be balanced with the lug nut holes securing the rim. The hub hole shape / location does not hold the wheel properly. The bolt on cap wheels could use the hub hole.
I assume good shocks and suspension components.
Lady72nRob71 is offline
Old March 12th, 2012, 07:24 PM
My old wheels had the bolt-on caps. The wheels on the car now have the snap-on caps. Rob, I don't understand what you're saying about the lug nut holes and hub hole location. Are you saying to have them ballanced on the car??? Oh, and all suspension parts are new. Thanks for the reply.
Bruce
Old March 12th, 2012, 07:43 PM
I have heard that these later wheels have to be held on the balancer machine with the lug nut holes. The nose of these wheels have a hole but it is not the right shape / size/ position for the balancer to hold them right. If the wheel is offcenter on the machine, the balance will be off.
I have seen these wheels put on a balancer and the fit is quite ill when held by the nose.
These wheels are known as "lug-centric", where as most wheels are "hub-centric". You might want to call around to see who can balance lug-centric wheels. Good shops know the difference. If they never heard of it, then try another place.
Old March 12th, 2012, 07:59 PM
That makes sence...good information. I have not heard of this type of balancing. There's a shop in Fort Worth that specializes in old car suspensions. I'll give them a call. Thanks.
Old March 13th, 2012, 07:56 PM
442_1972's Avatar
I worked in a tire shop 20+ years ago and our Coats balancer at that time had various sized cones that worked with hub-centric wheels and a special adapter that allowed you to secure the wheel to the balancer when working with lug-centric wheels. I don't remember using the lug adapter that much, but I do remember that it was a pain compared to using the cones. One thing that I learned was to pay close attention to the lateral and radial runout of the tire/wheel as it spun on the balancer. Sometimes runout that was not directly the result of a bent or bad rim could be improved or corrected by breaking the tire down, spinning it on the rim, and re-seating it. I would sometimes do this same procedure, if the balancer called for a lot of weight to get a neutral balance. In some cases, I'd try another tire on the same rim to see if that would make a difference. I guess what I'm trying to convey here is that just because some weight can be pounded on a wheel to get the balancer to read neutral, doesn't mean the tire is properly mounted and balanced. Hopefully, the problem is simple to resolve!
442_1972 is offline
Old March 14th, 2012, 07:22 AM
AZ442's Avatar
trany output shaft bushing on my 4 speed was my problum.
AZ442 is offline
Old March 14th, 2012, 11:01 AM
Rickman48's Avatar
How'd you come up with that??
Rickman48 is offline
Old March 14th, 2012, 11:26 AM
AZ442's Avatar
after months of balancing wheels, replacing tires, replacing driveshaft and wheel bearings, the bushing in the ST10 4 speed was the cause of my highspeed vibration.
thanks for asking.
AZ442 is offline
Old March 21st, 2012, 06:51 PM
72hurst's Avatar
Tire discount can balance the for you. Just tell them to use the "fingers". That's what they call them. I had mine balanced with them and I don't haveany vibrations at all.
72hurst is offline
Old May 29th, 2012, 09:26 PM
elliseB's Avatar
That was pretty interesting. It might be good for safety purposes.
elliseB is offline
Old May 29th, 2012, 10:28 PM
If the car ran smooth when the 14 SSIII's were on, it has to be the new wheels. Rubber shouldn't be the issue - it can be balanced. Are the wheels true? They can look good, but I'd check all of them or run out to be sure. I'd bet one of them is bent somewhere - inner or outer rim
Allan R is offline
Macadoo
June 24th, 2014 05:36 PM
STLCRZY
Drivetrain/Differentials
May 4th, 2014 12:49 PM
smcurro
Paint
January 29th, 2012 02:31 PM
Robert Kiedrowski
October 10th, 2009 10:36 PM
bo1962
June 22nd, 2009 01:33 PM
Quick Reply: High Speed Vibration, '72 H/O
