Got the beattch out!!!!
Old Jan 30, 2014 | 08:32 PM
  #41
scooter123's Avatar
Second attempt at setting the pattern tonight.....been writing down all the shim combinations.. what do ya think....
Old Jan 30, 2014 | 10:21 PM
  #42
scooter123's Avatar
Old Feb 1, 2014 | 11:45 AM
  #43
scooter123's Avatar
took another shot at the pinion and gear setup last night......0.040 on the pinion....and 0.010 backlash and here is the pattern
also bead blasted the backing plates and painted
Old Feb 1, 2014 | 12:16 PM
  #44
76olds's Avatar
Hookers under Hood
Your well equipped nice job on the plates your rear will look awesome. I can't answer any of your ?s wish I could thou. My rear is a few months away from doing yet still tooo cold here. Jim did mention to me to start with the original shim or a .038 shim to start.
Your defiantly giving me the confidence I needed to take on a job like that. Put-r-ther videos are all good too !!
Old Feb 1, 2014 | 10:22 PM
  #45
scooter123's Avatar
So here is the original pattern that came on the gear from new.....I guess I need to match this
Kinda getting tired of pulling this thing in and out.....must have did it over 40 times now
Old Feb 3, 2014 | 07:11 PM
  #46
scooter123's Avatar
Final pattern....done and done!!!!
This was a big learning curve for me being the first one ive ever done. I must have taken this thing out about 40 times.....writing down every time what shims were used and where.....and pics to go with it!!!
I ended up with 0.043 in the pinion and 0.008-0.009 backlash
Thanks for all the help.
Old Feb 8, 2014 | 12:34 PM
  #47
scooter123's Avatar
Well getting ready to set the preload on my bearing..... Made myself a little tool and the use of my breaker bar!!
Those Oldsmobile bible come in handy.... Lol
I
Old Feb 8, 2014 | 02:28 PM
  #48
76olds's Avatar
Hookers under Hood
I'm going to have to start working out Lol, I may not have the strength to handle that job . I would need a bible after cursing, My wife says everytime I work on the car my friends come out, meaning the F-bombs, Oh lick comes out at times too, Their never allowed to stay for supper !!! I figure I will have to pay the $$ to get mine done .
Old Feb 8, 2014 | 02:54 PM
  #49
scooter123's Avatar
Hey....if ya have the coin to get it done that's a great way to go!!! I how ever wanted to learn how this was done and im no mechanic but I do consider myself pretty mechanically inclined......and this was a great learning experience for me!!
If I were you I would give it a try.....you can do it!!!
Old Feb 11, 2014 | 08:49 PM
  #50
scooter123's Avatar
Well I finally got the pinion preload set tonight, after a second try.
First try went over....50 inch lbs....second time 30 Inch lbs ....Now im happy!!!
I also installed the axles and im ready to install the cover so my next question is proper gear oil for a posi carrier....my book says it will hold 4 1/4 pt.....what is this in litres...4litre?????
also some kind of additive needs to be in there??
Old Feb 11, 2014 | 09:15 PM
  #51
copper128's Avatar
Lt. Buzzkill (ret.)
4.25 pints = 2.01 liters
Old Feb 11, 2014 | 09:19 PM
  #52
copper128's Avatar
Lt. Buzzkill (ret.)
Oh yeah, 80W-90 mineral-based gear oil and GM #88900330 posi lube
Old Feb 12, 2014 | 02:57 AM
  #53
Originally Posted by copper128
... 80W-90 mineral-based gear oil...
Though there's no reason to think that 75W140 synthetic, along with the proper friction modifier, would be any sort of a problem.
Old Feb 12, 2014 | 08:56 AM
  #54
Nice job Roger. I used 80/90 conventional gear oil with posi additive. The gear oil comes in tubes with a long thin nozzle you cut to make filling easier. Put in 2 tubes, then the gear oil, and top up to where the gear oil starts to ease out the hold. Install the bung and tighten. Make sure the diff is either reinstalled in the car, or AT THE SAME ANGLE it will be when installed or you could end up over filling.
You are probably right. My carrier is reconditioned series 3 and lightly used gears so I stayed with the conventional gear oil/additive. One thing I was cautioned about is that synthetic MAY be too slippery for the clutch packs on these older carriers. If Roger has a modern carrier it probably isn't an issue, but I'm not really sure. I'd be curious to know why you spec'd 75/140 instead of 70/90? The gear oil question has been discussed on several other sites and the general concensus is that for stock posi units like this synthetic often doesn't provide the requirements of SLIP and ENGAGE/GRIP. C'mon back?
Old Feb 12, 2014 | 11:31 AM
  #55
I came up with 75W140 because that's what's specified, along with friction modifier, for the posi differentials in my Jeep, for heavy duty use.
I have no other experience with synthetic lubes in limited slip differentials.
Old Feb 12, 2014 | 12:45 PM
  #56
Ah so, Eric san. I oopsed too. Should have said 75/90 synthetic. I think the Jeep posi's specify that 145 stuff because it's less likely to change consistency when it gets hot? My 1983 Regency Brougham had a limited slip diff. When I had to change the fluid in it, there wasn't really any choice - it had to be 80/90 with additive because the synthetics were just starting to evolve and they were way to expensive anyway. I guess I might be cheap like you when it comes to some stuff.
Old Feb 12, 2014 | 01:06 PM
  #57
Cheap and simple is good.
Old Feb 12, 2014 | 05:49 PM
  #58
scooter123's Avatar
Here Is what I picked up Al....I will pic another tube...wont be adding the fluid until its back under the car!
Old Feb 12, 2014 | 06:36 PM
  #59
Same stuff I bought Roger but in smaller size containers. Should work just fine! I needed a lot more gear oil in my diff only because I installed that W27 cover. It requires almost another litre of gear oil. So with the added gear oil and finned cover it should keep the gears from getting overheated.
Old Feb 14, 2014 | 07:16 AM
  #60
scooter123's Avatar
Well I was hoping to install this diff back into the car this weekend but I went to order the last part...... Upper control arm bushings and my local parts store napa told me there were none in Canada......... So I went up the street and got them ordered and will be here in a week. I thought this would be a common part for any gm 10 bolt diff.
Old Feb 14, 2014 | 07:33 AM
  #61
That's a shocker. Hmmm, while you're at it doing those bushings you MAW do the front ones and the sway bar link kit. Chances are they are all in need of replacement. Did you go with rubber or poly bushings? Getting them back in the differential ears can be a beatch too.
Read a tip about that. Freeze the bushings overnight, and just before install heat up the ears of the diff. They're supposed to go in a lot easier that way. I read that after I did mine of course.
Old Feb 17, 2014 | 11:44 AM
  #62
scooter123's Avatar
Today I painted the rear drums......Im still waiting on the bushings for the diff and will put this sucker in!! Wish it was back in....I would have taken it out for a spin!!! Beautiful day here!!!
Old Feb 17, 2014 | 12:22 PM
  #63
76olds's Avatar
Hookers under Hood
Looks awesome, I can't wait to get into mine.
Old Feb 17, 2014 | 12:31 PM
  #64
So far so good. Looks like pressing in your bushings will be a lot easier than on an A body. Those horns don't appear to have any clearance issues I had on mine.
Purty heavy to move around isn't it?
Old Feb 21, 2014 | 07:12 PM
  #65
scooter123's Avatar
Got the last of the parts for the rear diff today.........the bushings!!
I bought a ball joint press kit from princess Auto on half price and it took some fandangling......but I made it work!!!
Hope to get this thing in on the weekend and get the brakes bled....and ready to Roll
Old Feb 21, 2014 | 08:02 PM
  #66
Well done.
Old Feb 22, 2014 | 10:45 AM
  #67
scooter123's Avatar
went out this morning and Installed this rear diff in less than 1/2our......got to love it when it all goes well working alone on such a big item!! With the right tools...jacks/ jack stands it was so nice!!
So now it on to bleeding the brakes.....when I disconnected the lines I made the mistake of not pluging off the main line
So Any tips On bleeding the lines.....
step 1 keep both the resvoirs on the master cylinder full...
step 2 have a second person pump the brake then open and close the bleed screw till we have solid fluid flow
Old Feb 22, 2014 | 11:25 AM
  #68
Roger,
Glad it was easy for you to install the bushings. Why the heck didn't you just borrow the press kit from PartSource tool loaner program???
re: bleeding brakes. Check your MC. If it's empty you need to remove it and bench bleed it before you do anything else. If you do this you will need some plugs for the MC outlets. You can pick em up free at almost any car repair shop.
Bleeding you can do by yourself or with help. Here's how I did mine.
1. Get a clear plastic hose that fits over the bleeder nipple. Have enough hose to go down into the bottom of a glass jar.
2. Fill the MC reservoirs but don't cover them over. Keep the BF handy
3. Open one side rear bleeder and let it gravity bleed for about 20 - 30 minutes. In that time you should start to see the BF slllowwwwllly filling the jar. There should be bubbles at first which will change to clear fluid. If the bubbles 'hang up' put the cap on your MC and press the brake pedal gently to encourage flow, but only once or twice at this stage.
4. When the hose appears to be solid BF, close the bleeder and repeat the process on the other side.
5. When both sides have been gravity bled, you can then follow the step 2 you have in your post.
I'm guessing that the bushings haven't been torqued yet.
General rule of thumb on bleeding: Sequence as follows- Right rear, left rear, right front, left front.
Old Feb 22, 2014 | 12:45 PM
  #69
scooter123's Avatar
Al the nearest auto source is 160km round trip.....So the ball joint tool worked just fine!!
Old Feb 22, 2014 | 12:57 PM
  #70
Gotcha! IIRC the torque on those rear control arms is 80 ft/lbs with the weight of car on the suspension. I found that lowering the axle onto jack stands worked ok for that. Just have extras under the frame for safety. Clearances can get a bit tight.
Old Feb 22, 2014 | 04:25 PM
  #71
Tightening bushings at standard ride height is very important, and it's done on today's car lines too.
Old Feb 22, 2014 | 05:51 PM
  #72
scooter123's Avatar
went through the proper steps in tightening all the bolts........got to the last lower control arm bolt and the Beaaatch went on cross threaded...****!!!
So can I just take this bolt to a shop and get them to run a die down the bolt and a tap through the nut??? Is this a 1/ 2 bolt with 11 TPI ???
Or can I just buy a new nut and bolt from napa
Old Feb 22, 2014 | 06:00 PM
  #73
76olds's Avatar
Hookers under Hood
1/2 -11 is pipe tap, Too bad it wasn't a 1/2 -13 it would be a little easier. That sucks I'm sure the would have a cheap pipe tap and die, you may have to get the set thou. Or just giver with some copper anti seize spay and tighten it, if you need to take it out later just torch it or drill it out would that work?
Old Feb 22, 2014 | 06:15 PM
  #74
How does it cross thread when you have to start them out by hand?
Too bad its so friggen cold here right now or I could dig up some spares I have. I believe they're in the shed out back. You probably can buy a spare from NAPA or Partsource. Last time I was at Partsource they had a bin of G8 different sizes and locking nuts. Crappy tire might also have em. I wouldn't put a trashed bolt/nut on a suspension part. It HAS to be good.
Old Feb 22, 2014 | 07:15 PM
  #75
scooter123's Avatar
so just grab a 1/2 grade 8 bolt and lock nut??? That's easy enough!!
This thing will be out on the road before the snow is gone.................yyyyyyyyyyyyyyyyyyyyyiiiiiiii iipppppppeeeeeeeee!!
lol
Old Feb 22, 2014 | 07:53 PM
  #76
76olds's Avatar
Hookers under Hood
I can't wait to hear your response to the improvement. I getting anxious to get mine done and laying a couple strips down myself.
Old Feb 23, 2014 | 12:12 PM
  #77
scooter123's Avatar
At - 25c here today I fired p the 71 olds....boy it was sure nice to hear the 455 again!!
I just took it for a bout a 1 km run in the highway....babying it all the way....I know I have to break in the new gears!! All seemed great no weird sounds or vibration What a great feeling working on these old cars!!!
Old Feb 23, 2014 | 01:44 PM
  #78
Nicely done Roger. How'd the drive turn out? I guess the brakes are working too huh?? She sounds pretty healthy.
Old Feb 23, 2014 | 02:03 PM
  #79
scooter123's Avatar
It went well Alan.....I got the brakes bled last evening using a one man bleeder tool...worked great!!
Now I just need to track down the new spedo gear thing for the th400 trans
from 3.08 to 3.73.....ant idea where to purchase such an animal????
Old Feb 23, 2014 | 02:11 PM
  #80
Try these guys Performance Transmission and Parts
