Gear swap - 1965 BOP 8.2 rear
Old Jan 26, 2020 | 07:19 AM
craig442's Avatar
Car currently has 3.90 gears and want to swap for something more drivable. I wanted 3.23 but from what I have read the tallest gear for this rear would be 3.36, but 3.36 was not an offered ratio for the 65 442 (4.33, 4.11, 3.90, 3.55, 3.23, 3.08, 2.78). And if I wanted 3.23, what else would need to be swapped? What are my option here? Any help would be appreciated.
Old Jan 26, 2020 | 09:19 AM
66-3X2 442's Avatar
You will need to change the carrier to use a 3.23 gear set. You can use a 3.36 gear set on the 3.90 carrier. The 3.36 gear set is a Pontiac gear but will work fine on your carrier. I have a ser of 3.23 gears if you need them.
Old Jan 26, 2020 | 09:53 AM
jmos4's Avatar
Hi,
I have a extra 3.36 gear set if you wanted to trade as I was looking for either 3.73's or 3.90's for my 65 Cutlass as I am going to be running a 200r4
Regards,
jmos4
Jun 5, 2018 05:32 PM
RustRocket
Drivetrain/Differentials
Sep 4, 2014 11:46 AM
jcl
Sep 18, 2013 12:51 PM
devmar07
May 2, 2013 09:34 PM
65Delta88
20
Jan 14, 2009 07:15 PM
