Gear Ratio Recommendations
Old Feb 17, 2008 | 10:36 AM
Maverick's Avatar
Dr.Olds Illegitimate Son
Question Gear Ratio Recommendations
Hi all,
I have a '71 Cutlass Supreme ragtop that I would like to upgrade the rearend with.
Its a 10 bolt that is open. I'm sitting at around 360 hp with the motor , but it just doesn't hava a lot of snap off the line. Pulls like a damn on the highway.
I would like to go to posi and more umph, but still highway drivable.
Your thoughts ?
Old Feb 18, 2008 | 02:48 AM
Edveen's Avatar
Would you happen to know the gear ratio currently? Im going to assume you have 2.xx gears and a 3-speed.
If my assumptions are correct, then a think 3.08's-3.23's gears are the sweet spot for highway and street!
Ed
Old Feb 18, 2008 | 08:01 AM
Maverick's Avatar
Yes it's a TH350 and I can only imagine that the rear end ratio is in the 2's . The car is currently in storage.
Old Feb 21, 2008 | 06:40 PM
desert442's Avatar
New 4-4-2 Owner
hmm, i do agree that the 3.23 gear ratio is a good one. But don't overlook the 3.55 gear. Gives a little more lower end torque response for a snappy start off the line, yet retains a good amount of drive-ability on the highway.
Myself speaking, my 67 442's 400 BB motor currently has a 4.33 rear-end gear ( stock from the NC Dealer) to go through. Great for blasting off the line with, but I can't drive it on the highway.
Anyhow, just my own humble opinion. Good luck with the project.
desert442
Old Feb 21, 2008 | 08:12 PM
88 coupe's Avatar
Junior Member
Originally Posted by desert442
........ stock from the NC Dealer ........
Do you mean "Dealer installed" or "as optioned" and purchased from the Dealer?
........ but I can't drive it on the highway ........
I have 4.30 and 4.56 in my Coupes. I do not have any problems at 65 miles per hour.
Norm
Old Feb 21, 2008 | 09:17 PM
Jolly Green's Avatar
What RPM's are you guys getting at 65-75 miles per hour? I have a TH400 and my third gear is a 1:1 so it would seem that my RPMs would be a lil high. I haven;t been able to ID my rear but I think its a 3.42. Its a stock 12 bolt 68 442 rear.
Old Feb 21, 2008 | 09:18 PM
Maverick's Avatar
What do you cars redline at ?
Old Feb 21, 2008 | 09:42 PM
88 coupe's Avatar
Junior Member
Depends on your definition of "redline".
For my 437, it might be anything from 5400 (peak HP) to 7000+ (where I think it will break) RPM.
Norm
Old Feb 22, 2008 | 03:38 PM
don71's Avatar
same but different
I will be installing a 3:23 geared O rear....just waiting for the snow to melt I can't wait to replace the 2:56 open rear.
I have it figured to up the rpms by about 600. From 22-2300 to 2800rpm or there abouts, at highway speed.
Don't forget your speedometer reading. You"ll need a new driven gear at the tranny. In my case, a 29 tooth.
Old Feb 23, 2008 | 02:27 AM
88 coupe's Avatar
Junior Member
Originally Posted by Jolly Green
........ third gear is a 1:1 ........ I think its a 3.42 ........
http://www.csgnetwork.com/rpmcalc.html
Norm
delta881972
Drivetrain/Differentials
Feb 26, 2010 09:42 AM
442 Guatemala
Jan 15, 2010 10:43 AM
squirell
Jul 7, 2009 09:01 AM
jeffs 89 cutlass salon
Aug 21, 2007 07:57 PM
442 Guatemala
Jun 11, 2007 10:19 AM
