Gear compatability?
Gear compatability?
Would a gear set out of a later model GM half-ton truck work in my ’71 Cutlass? Both are 8.5” 10-bolts right?
Cutlass rearend doesn’t appear to be a Type-O. Does have bolt-in axles.
Thought I might could hit up the pick-n-pull and snag some
gears and a limited slip.
The 1971-72 rear axles are "corporate" 8.5" ten bolts, except that they have the bolt-in vs c-clip axles. Any internal parts (gears, bearings, posi) that fit the Chevy 8.5 car axle also fit this. I don't know enough about the truck axles, however, to say they are the same as the car axles.
Richmond Gear's web catalog shows all the vehicles with compatible ring and pinion gear sets:
https://www.richmondgear.com/wp-cont...n1.pdf#page=31
Truck 10 bolt 8.5 corp. 1971-1999
ALL 8.5 gears are the same.
Will interchange in all 8.5 10 bolt corp. rears.
10 bolt cover 10 bolt ring
Posi units too will also interchange not a problem....BUT you DO NOT WANT a truck auto locker GM limited slip posi unit locker....THEY asre NOT designed for car type playing.
They are low speed operation units 30 MPH and under
over that they do not lock.
So do not bother looking for the TRUCK posi.
You want car unit or aftermarket posi units.
NOW AFTER many years gone by...there are some pick apart trucks that I HAVE SEEN car units in them as guys transferred
over to them and or aftermarket if the stock unit blew up ....SO do open them and check.
THe Auto locker is NOT a bad unit...IT IS just not made for burn outs and fun stuff we all like to do with the cars.
THESE ARE ALL GOOD UNITS IF THEY LOOK LIKE THIS GRAB IT.
Jim Mitschke
JD Race
Jim Mitschke
JD Race
Good deal. Thanks for info. Went and scouted out today. Grabbed a supplemental electric vacuum pump for brake booster.
Counted at least 5 8.5” 10-bolts with 3.73s and G80 locking rearends. Going to get 1 tomorrow.
Is the pinion yoke same spline, etc.
71OldscutlassS
Drivetrain/Differentials
January 25th, 2020 07:43 AM
